Old 08-23-2014, 12:53 PM
radracer55 radracer55 is offline
Default 1811 belt???
I recently got my 1811 back running when I purchased and installed a new pto clutch. Now I need to replace the deck belt and I found that part number (954-3005).' Im trying to find the belt/part number for the belt that goes from the pto clutch to the top of the outside of the mower deck.
Thanks
Kyle
Old 08-23-2014, 01:06 PM
What deck do you have? Assuming that you have a 50C it looks like you need a 954-3003A
Old 08-24-2014, 08:06 PM
yes it has the 50 inch deck. Im using this to look up the part numbers. where did you find it?
http://www.partstree.com/parts/?lc=C...00+-+799%2C999
thank you
Kyle
Old 08-24-2014, 08:52 PM
You can find it here:
http://www.partstree.com/parts/?lc=c...&dn=0059900001
Old 08-26-2014, 04:04 PM
gophred's Avatar
gophred gophred is offline
aren't those belts about 15-$20 at tractor supply? $51 seems really high. not sure where I have seen them but there are some good cross references for gates belts online. TS also has the measuring tool if your old belt is still whole
Gophred
2 - 1811's with 50C decks, one mows the other is waiting on deck, 129 (my sons retromod)-, hydro lift, custom 3 pt with a trailer ball , foot pedal speed control, used for trailer hauling. 129 (mower) 42" deck, foot control, 1810 with 44C - next in the slow death march of mowing the camp. a few 1200 series parts rigs. 2017 Kubota b2650 loader mid mower.
Old 08-26-2014, 04:12 PM
Agreed, I went to tractor supply and got a "husky" brand blue belt. 89" I think it was. You will have a little adjustment on your mule drive tension pulleys if you need to. Good luck, TB
