Old 08-26-2014, 03:11 PM
Seabees Seabees is offline
Default 128 Starter keeps on starting
Ive got a new problem that has me stumped.
I fueled up my 128 to mow the back yard and I restarted it.
The starter/generator stayed as a starter and the battery wire to the V/R started smoking. I disconnected it before it did any damage.
I replaced the V/R and now when ever I put the battery wire on the post, my starter turns over even if the key is in the off position.
I suspect a direct short inside the S/G.
Any suggestions before I start disassembling S/G
Old 08-26-2014, 03:46 PM
Check the starter solenoid.
Old 08-26-2014, 04:05 PM
FFGino FFGino is offline
Default always starting 128
I had that same problem on my 128. It reportedly had set for about 4-5 years UNDER a deck!!! Things were kinda stuck and I had a lot of cleaning to do. When I finally got around to re-installing the engine, every time I touched the positive cable to the battery, the engine turned over.
After thoroughty tracing all the wiring to it's supposed/stated ends, I tapped on the voltage regulator and the sparks didn't fly anymore!!!
After setting for so long, the points(which set?) inside the regulator had apparently stuck/corroded together. I didn't use a BFH and lots of muscle, I gently tapped the unit with a small ballpein hammer and that did the job.
Give it a try. It may be the problem.
FFGino. Happy Cubbing!!
Old 08-27-2014, 01:44 PM
Sounds like you have the wrong voltage regulator on it.
I don't have all of the information here with me but I believe if you remove the blue wire from the v/r it will stop doing that.
Old 08-27-2014, 02:02 PM
johncub7172's Avatar
Exclamation
The starter solenoid is NOT the "electrical bridge" between the s/g and battery.
Go see OCC member Old Iron's write up on this matter.
Old 08-27-2014, 03:35 PM
When he said:
.....when ever I put the battery wire on the post, my starter turns over.....
I took that to mean the wire running from the stater solenoid to the S/G. Perhaps I misunderstood.
No one here was saying that the solenoid is the "bridge". However, it is..... when you are starting the machine. Just not when it is charging the machine.
To the OP:
Perhaps a little clarity is in order as to which wire you are referring to as the "problematic" one.
Old 08-27-2014, 09:43 PM
Default 128 keeps starting
The problematic wire is the wire that goes to battery post of the v/r. Even if I have the key out of the ignition, when I touch the wire to the terminal the s/g try's starting.
I'm thinking there is a short in the s/g.
If I keep the battery wire off of the v/r and the battery has enough juice, I can turn the key and the motor will start like normal, but the battery won't charge.
This is what leads me to believe it's a direct short in the s/g.
My other option is the ignition switch. I will get out my multi meter tomorrow and start chasing.
My buddy gave me his spare s/g to check against mine.
If all else fails I will track down someone in southern york county that rebuilds generators and pay them a visit. Any suggestions ??
Old 08-27-2014, 10:08 PM
By what you're describing it really sounds to me that your voltage regulator is causing this. I know that you said you replaced it for the same problem but are you sure about the wiring being in the correct locations and the new regulator is correct?
Old 08-28-2014, 01:24 AM
Did you replace the regulator with a used one, or new?
If used, did it come off a cub cadet, or was it just one that "looked the same"?
Are you sure you wired it correctly?
It's really pretty simple to test the components. Shouldn't take more than a few minutes.
Here is a link to the chassis manual for your machine:http://www.onlycubcadets.net/forum/s...ead.php?t=4644
Here is a link to the wiring diagram for your machine:http://www.onlycubcadets.net/forum/showthread.php?t=22
Old 08-28-2014, 07:51 AM
I agree. Had the same problem with a 129 that I was working on. Come to find out, I had the wire for the back lights jack on the regulator. Once I changed it around, problem solved. The ends look the same if it has a slider tabs on your regulator and this mistake is easily made if your wires are dirty and hard to distinguish.
