Old 05-26-2013, 08:32 AM
Leadslingingdaddy's Avatar
SWEET..!
If we ever get this property we have been looking at for the past year I need something like that!
Old 08-28-2014, 07:12 AM
A little up date on the Powerhouse engine. Went to use it yesterday and even though I had drained the gas before storing it last year. Couldn't get gas into the carb. What ever they use for rubber to make the hoses is junk. Also all of the vent lines had cracked. Removed all the EPA crap and tossed in in the trash can. Pulled the float bowl off, spotless inside. Removed the float and needle blew it out and a chunk of hose came out. New hoses and back in biz. Gotta get an in line shut off because the one on the bottom of the tank is not completely shutting off.
Got it up and running then mowed some stuff that was to wet, tall and heavy for the Supers to deal with. This thing is evil, I had about 6 stumps that stuck up about 3", they were a PITA to deal with when using the Supers, now they are only about 1" tall. Granted they were pretty rotten but it did the job of a stump grinder.
Old 08-28-2014, 08:00 AM
Looks like a great piece of equipment. That would be really neat if you could hook it up in front of your mower so you didn't have to tread on the grass and squish it down first. Glad you landed it!
Old 08-28-2014, 08:53 AM
c69ss396 c69ss396 is offline
They want $500 for this one, if it was even relatively close I'd be on it after seeing how well yours does.
http://limaohio.craigslist.org/grd/4634203427.html
Old 08-28-2014, 09:46 AM
That is a killer deal ! Wish my mower was as nice as that one is.
Thanks for the link, I just listed it in the C-list area, hope one of our members picks it up.
Old 08-28-2014, 10:47 AM
PaulS's Avatar
PaulS PaulS is offline
Sam that thing looks killer. Does it have any height adjustment other than pumping up the tires.
Old 08-28-2014, 11:31 AM
I have tried 3 different types of in-line fuel shutoffs so as not to have to access a difficult to reach tank shutoff.
I gave up,,,,,, the cheap in-line shutoffs let gas continue to flow.
I may, some day, go to
Air Power, Inc.
520 Apperson Dr
Salem, VA 24153
I think they will have a valve that shuts off,,,,
http://www.airpower-usa.com/
Old 08-28-2014, 01:44 PM
Yep you can bolt the wheel mounts in different holes.
Old 08-28-2014, 01:46 PM
Air Power, Inc.
520 Apperson Dr
Salem, VA 24153
John it's the factory shut off that wont shut off. Just put one of those cheap B&S plastic shut offs on, so far it's working.
Old 08-28-2014, 04:44 PM
If it wasn't so far away I'd own it already! I don't think you can beat the price either...
