Old 09-02-2014, 06:22 PM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Don't use Purple Power unless you keep it far away from the engine serial number plate. I used it to clean the Kohler engine on our Original. It worked great but it washed the engine tag clean, it's a blank piece of shiny metal now.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 09-03-2014, 10:35 AM
red56turbo's Avatar
You can get new reproduction serial number plates for Kohler engines. I think I saw them for sale on a Wheel Horse site.
Josh
Diesel Cub Cadets...........
Old 09-03-2014, 12:01 PM
If it was my engine I'd pull the tins, pressure wash it and wire brush the fins. If you want to get fancy maybe wire brush what you can get at with a small wire brush. I would not open it up as long as it runs OK. Some power blaster on things like the exhaust bolts probably wouldn't hurt. Thought about some aluminum brightener but I'm afraid it would corrode the steel items even worse.
Old 09-03-2014, 01:40 PM
o---o o---o is offline
When pressure washing, are there any certain areas to avoid spraying directly with high pressure?
Old 09-03-2014, 02:16 PM
Dont spray down the muffler. I personally like to pressure wash my engines in a tractor so the second I'm done I can start it so it dries off good, anytime I've ever washed a motor out of the tractor it wouldn't start later when installed it due to corrosion on the points.
