Old 09-06-2014, 01:14 AM
Default Lights of a different kind
OK, we have been through lights for our tractors, now help a brother out for my shop.
First, I'm looking for good screw in bulbs. That's what I have in the ceiling is eight fixtures. Used to be a guy could get good 100 watt bulbs and they seemed they would last a good while, now these new curly style things give off a weird color, and don't seem to like the cold and hot.
See in winter sometimes my shop don't have heat for a couple days, get's down to say 40* and them damn things don't last very long, and ain't cheap either. But I noticed even this summer I've been using more than should be.
Alright, you all get what I'm looking for. A good, long lasting, bright bulb....
I'm not going to change out to tube types or anything crazy, just want a good screw in bulb
Old 09-06-2014, 01:22 AM
johncub7172's Avatar
Todd, just trying to help. How about "outside flood bulbs" ? You know, they're like 4" around, but still screw into regular 110 sockets. Might make a good winter shop bulb. Check walmart,.....
Old 09-06-2014, 07:05 AM
Todd:
Yes, those CFL aren't any good for cold ambients. They have a "warm up" time and there lumen capacity is greatly reduced as the temperature falls.
I personally have not used these yet, but my next replacements, I'll be looking at LED's bulbs. They don't have the problems of the CFL's. They only issue is the initial cost. Once you get past that investment, they say you can expect 15 to 20 years of life out of them plus, there is ~80% reduction in operational costs.
Yep thank you EPA. Glad I stocked up on the old fashioned bulbs.
I may try some LED stuff at some point.
Old 09-06-2014, 08:21 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
X2 R Bedell
Old 09-06-2014, 09:52 AM
L E D bulbs do the same thing in the cold but the get brighter faster.
if you can find some 130v bulbs that are 150 watts they would last a loooooong time.
Up to 534 and counting...
Old 09-06-2014, 09:53 AM
First, I'm looking for good screw in bulbs. That's what I have in the ceiling is eight fixtures. Used to be a guy could get good 100 watt bulbs and they seemed they would last a good while, now these new curly style things give off a weird color, and don't seem to like the cold and hot....................
Just have to know where to look Since the 120V incandescent are no longer allowed to be imported, they are now 130V industrial lamps
You can purchase them from MSC
http://www.mscdirect.com/browse/tn/L...541+4288197083
Jeff
Old 09-06-2014, 10:01 AM
Stratmoore Farms Stratmoore Farms is offline
If you look for "Rough Service" bulbs, you can still purchase 100 watt incandescent bulbs. I get them at my local HVAC supply store. A quick look on Amazon shows that they have them as well. The rough service bulbs are made for portable drop lights, so they typically last longer than the standard bulbs.
Christ died for you, live for Him!!!
Bob
Old 09-06-2014, 10:26 AM
kostendorf's Avatar
They are also used for machines such as lathes, drill presses, milling machines, ect. and come in 75watt too. I've had one in a drill press for 10 years.
Old 09-06-2014, 11:08 AM
Calvins66Cub's Avatar
I go LED whenever I can. I have been slowly replacing every bulb in my house 1 or 2 per month. The CREE bulbs are about $8. Work great. They are very similar to incandescent. Especially good for kids rooms that somehow magically turn on ALL the time. About 1/10 the energy. As far as cold weather lighting I used to have fluorescent lights and incandescent lights in my garage in Indiana. Incandescent for immediate light, and then fluorescent fixtures for working. I remember it was so cold one winter, I even gave the fluorescent tubes a swipe with the propane torch.
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
