Old 09-07-2014, 09:35 PM
Tim.E's Avatar
Tim.E Tim.E is offline
johncub7172,,,,I think that first picture is the countershaft that the 1st,2nd and 3rd gears mesh into. The bottom picture, the one marked in yellow, I believe is your actual 1st,2nd and 3rd gears. But,hey I am no expert.
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 09-07-2014, 09:47 PM
johncub7172's Avatar
TIM E- Thank you. I was wondering, because I think its neat to have a 19 tooth second gear. Just wanted a little conformation.
Main shaft is the top shaft in the drawing. Counter shaft is the lower shaft.
Just last Saturday, I found these two items in a plastic bag, laying next to a huge track hoe with a big magnet. Thought they looked cool. I got a whole 5 gallon bucket load of stuff for 10 bucks.
Ok, so the hydros are faster. But I like the authority my 72 gives when moving up hills and grades with that continual constant speed. Down hill not so much.
Old 09-07-2014, 09:49 PM
Tim.E's Avatar
garnold, on stretching the wheelbase,,,I did not add any length to the frame in the front, I just moved the front axle forward 5 inches from the stock position. On the 106 build I added 3-7/16" to the rear of the frame using a piece cut off of an old frame. Then I moved the transaxle back 3-7/16". The reason I chose 3-7/16" is because I just bolted the front mount in the rear hole,which moved it back 3-7/16". Then of course, the drive shaft and brake linkage had to be 3-7/16" longer. On the 100 build, I moved the rear axle back 2" and made a new driveshaft and brake linkage 2" longer. All this to use 27" tall tires and to get a "cool looking stance" and to get more leg/arm room (I have long legs and arms) (not to make it go faster)
Old 09-07-2014, 09:55 PM
Tim.E's Avatar
johncub7172,,,you are right on the mainshaft/countershaft issue. So,to clarify,,I believe the three gears on the MAINSHAFT are your actual 1st,2nd and 3rd gears. I am continually learning (an making mistakes)
Old 09-07-2014, 09:57 PM
garnold's Avatar
garnold garnold is offline
Nice and thank you! I just got lucky and found out my neighbor is a welder by trade and likes beer. I can buy beer hahahaha. I'll talk more about this in your thread Tim. I have a 73 that wants to grow up to be just like your tractors
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 09-07-2014, 09:59 PM
Originally Posted by garnold View Post
So the gearing in a hydro is different then a gear drive from what I'm reading.
Kinda. The only "gears" in a hydro are in a reduction housing just before the pinion shaft. It gives it a little more torque. Not anything in there that can be changed really. You would have to have a gear made if you wanted to change the ratio. Hydro...... is a little different animal. If you curious about hydro's, read this.
Just for the sake of asking, can the gear ratio in a gear drive be stepped up to match a hydro?
Yes, you can. For the most part guys change the gears in the reduction housing. That way it speeds all the gears up a "stepped" or "calculated" amount. (Based on the new ratio) Or, companies like Midwest Super Cub make different gears. Pullers are way ahead of you.
Also, again for the sake of learning, would the gearing in a gear drive then make it a more powerful tractor in regards to towing? This is not going to become a what tractor is better then the other thread, just looking to learn some stuff here.
Ummm.... yes. It's all about torque. That is why no one want's a hydro for 1.) pulling, 2.) plowing. Not that it can't be done.... just not as well. I plow with a hydro, but it's not my first choice.
I'm very aware of how gearing works so this is kind of interesting.
Then you shouldn't really have many questions.
So, how do you identify a 19 tooth second gear? Here, you see what is labeled "second gear".
On this part, marked with yellow, I counted 19 teeth:
The shaft in the first pic is the counter shaft. It should have a 33 tooth second gear if it mates with the other shaft you pictured. The gear marked in yellow, is the second gear sliding gear. Yes, it should have 19 teeth.
Now, if I wanted to be smart, could I use those parts and make the gear drive faster than a hydro? Just kidding, I have no plans for that, lol!
No..... not really. Not those parts. You'd have to change the reduction gears. Or, buy a different second or third gear from someone like Midwest Super Cub.
Old 09-07-2014, 10:01 PM
johncub7172,,,you are right on the mainshaft/countershaft issue. I had them backwards. So,to clarify,,I guess the three gears on the MAINSHAFT are your actual 1st,2nd and 3rd gears. I am continually learning (an making mistakes)
Actually, the gears on the topshaft, and the bottom shaft make up a "gear set" (1st, 2nd, 3rd). It takes two gears, and when you change the number of teeth on one, you usually have to change them both. That is why the counter shaft bolts together.
Old 09-07-2014, 10:09 PM
Merk Merk is offline
garnold,,,,,,,,,,,,,,,,,,,,That may be my 106 build that you are referring to. What I have is a transaxle out of an early 100 which has the lower second gear, just like what Merk said. It seems this lower second gear is only slightly faster than first gear. Merk explained it well. There were no "options" on gear ratios ,but they used different second gear ratios on different models through the years. I think first and third gear is the same on all gear drive models. By the way, hydros are definitely faster (top speed) than gear drives in third gear.
First and third gears were the same on all gear drives.
Project Uncle Dick
Cub Cadet 70
