Old 09-12-2014, 07:45 PM
dr..mach dr..mach is offline
Default 982 Front PTO switch is killing the engine - help?
I have an IH build 982 and need some help. There is no mower deck on it right now. I started the tractor and decided to turn the front PTO on to make sure it was working. When I flipped the switch the engine dies. I assumed the clutch went bad so I disconnected the wire to the clutch. Again I flip the switch and the engine dies. Maybe the switch is bad I thought. I have a spare PTO switch so I changed it out, same thing. Now where is my problem? Not sure where to go from here. Any help appreciated.
Old 09-12-2014, 08:29 PM
seawood seawood is offline
were you setting on the seat when you tried the switch
Old 09-12-2014, 09:56 PM
Yes I was. Any ideas? I'm stumped.
Old 09-12-2014, 10:01 PM
A fault in the safety switches. Perhaps the seat switch is bad, or no longer wired up. Could even be a faulty PTO switch. Get a wiring diagram and start tracing!
Old 09-12-2014, 10:14 PM
cubby102's Avatar
cubby102 cubby102 is offline
My guess is also the seat switch my old 782s was doing just that and the seat switch plug had vibratedoff
Old 09-13-2014, 06:37 AM
From the ID Tag on your tractor, what is the exact Model and Serial numbers so I can look at the correct Wiring Diagram.
