Old 09-21-2014, 03:46 PM
BigB87's Avatar
BigB87 BigB87 is offline
Default LP head
Can anyone show me what the top and bottom of a lp head looks like. I know the head bolts are flush with the fins but not sure what the bottom looks like. I bought a 10hp kohler this weekend for 45 bucks missing the s/g and pto clutch. PO said it just stopped running. But no head gasket from what I can see. Just wanted to see if I maybe found a lp head.
Brandon
CC models: 86, 100 w/hanban sickle mower & 1872
1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade
1965 100 w/hanban sickle mower
1989CCC 1872 w/50c mower
Old 09-21-2014, 05:37 PM
Lew has a picture of a carboned up LP head here http://www.onlycubcadets.net/forum/s...7&postcount=41
Old 09-24-2014, 03:05 PM
BigB87's Avatar
I don't think its a lp head. The one on the left came off my mower and the one on the right came off a 10hp I just bought. Looks little different. Is it a good head for power or what
Brandon
Old 09-24-2014, 04:04 PM
I think the one on the right is a newer gen, but could be an LP. The relief looks too deep to me to be an LP. I'm sure it's a newer generation style head.
This is an LP head:
Old 09-24-2014, 04:32 PM
BigB87's Avatar
Well jmech the bolt holes are flush across the top of the head. But even if it is a newer generation head is it any good
Brandon
Old 09-24-2014, 04:37 PM
If it's not cracked, clean it up and plane it. Looks fine to me!
Old 09-24-2014, 10:08 PM
cnixon's Avatar
cnixon cnixon is offline
[QUOTE=J-Mech;288206]I think the one on the right is a newer gen, but could be an LP. The relief looks too deep to me to be an LP. I'm sure it's a newer generation style head.
J-Mech is right on. Neither are lp heads
Old 09-25-2014, 02:58 AM
BigB87's Avatar
I knew the one on the left wasn't. Just wondering if the newer generation head will give any more power or burn fuel better
Brandon
Old 09-25-2014, 08:16 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
best way to id a LP head is no dump area between the valves and the cylinder. just flat. the head on the right is a basic 10 hp head. its got a little more compression than the 12 hp head on the left. you can put them on 12's and 14's and they work fine
