Old 09-26-2014, 10:36 AM
Group_44's Avatar
Group_44 Group_44 is offline
Default What does it fit?
I ran across this snow blade on the local CL, the owner says it is a universal fit which I question. I am looking for a blade for my 2082 super and wanted to know if I can fit this. It looks like this lifts from the center like the newer style tractors. The model on the blade is 190-302-100. I have been following the thread about the wide frame plows on the Cyclops, it seem like it would be easy to adapt one of those to fit with a few pieces of steel and a welder.
Old 09-26-2014, 10:38 AM
jimbob200521's Avatar
Doesn't appear that it "officially" fits that machine.
http://www.partstree.com/parts/?lc=c...60+-+836%2C000
HOWEVER, that's nothing a welding torch, maybe some steel, and an angle grinder couldn't fix
Edit: That being said, with how often I see blades on craigslist, unless you're good with fabricating, I'd just skip it and keep an eye out for an appropriate blade.
-Ryan
Old 09-26-2014, 10:41 AM
A blade for your 2082 isn't hard to come by. I wouldn't waste time modifying that one. Besides, it's for a LT, not a GT, let alone a SGT. I would imagine even if you mounted it you'd more than likely tear it up.
Old 09-26-2014, 10:51 AM
That blade is for a 2000 and maybe a 3000 series, didn't check on the 3000.
Old 09-26-2014, 12:55 PM
Group_44's Avatar
Sorta figured it was for a newer style Cadet like the 2000 series , the guy selling it said it fits everything. I guess with a big hammer and a torch he's right, but I think I'll wait for the right one to come along. I see by the attachment guide the blade for my super is 54", is there a narrower blade that will fit the super's mounts, I have a 48" gate and the wide blade just won't fit.
Old 09-26-2014, 01:06 PM
Angle the blade when you go through the gate, then it'll fit. I've got a few narrow spots I go through with my 54" and that's what I do.
-Ryan
Old 09-26-2014, 01:22 PM
Sometimes...... you just gotta step back and think outside the box a little.
Simple solutions always get overlooked. I'm guilty too.
Old 09-26-2014, 01:45 PM
Group_44's Avatar
What is the width of the 54" blade with it angled? I have also had issues in the past with tearing up the grass on the side the walks (also 48") with the blade on my old 1650.
Old 09-26-2014, 03:03 PM
Couple things; first, the blade is still 54" angled seriously though, I'm not sure how wide it is angled but there is one spot in particular that I go through that is pretty narrow, but with the blade angled, I'm able to "walk" through it. I angle all the way to one side then come at the gate straight on. At the last second, I cut the wheels to allow the farthest out corner of the blade to go through, then cut the wheels the other way to get the other side through. Sounds a little weird to explain, but it works. Second, what 48" blade did you have on your 1650? They only made a 42" and a 54" for that machine
-Ryan
Old 09-26-2014, 04:13 PM
I think he meant the sidewalks are 48" wide.....
