Old 10-06-2014, 02:30 PM
alsparl alsparl is offline
Default Sealing Trailer Deck Boards
I am needing to put a sealer on my trailer deck boards for the first time and was interested in what you all have done, what product you have had the best results with.
Thank you for your time.
Aaron
'83 782 #723927
****original KT series 1 engine
****added dual hydraulics from older, donor 782
'04 SRC621
'95 Magnum (M18S) spare engine
****spec 24646
****s/n 2507913316
Old 10-06-2014, 06:43 PM
IHinIN IHinIN is offline
You might try sealer meant for house decks. It is usually good for 3-4 yrs.
Old 10-06-2014, 06:48 PM
Calvins66Cub's Avatar
I am sure this will cause some controversy, but, used motor oil is a great wood preservative. And, it's free. I painted a fence with it. after 7 years the wood looked nearly the same. Albeit we don't get much rain here, it was more like adding sunscreen.
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 10-06-2014, 08:18 PM
Tiny's brother Tiny's brother is offline
Default Thompson's Waterseal
I just did my 7' by 16' Landscape trailer using a gallon of Thompson's Waterseal- Clear, $17 at Wal-Mart. I used a 1/2" nap Roller and a disposable plastic tray, disposable gloves too. 15 minutes and I was done, throw everything but the roller handle away. I had already pressure washed it and let it dry for a few days. The last treatment lasted about 3 years and it sits outside year round.
Old 10-06-2014, 11:51 PM
That's all we ever used on hay racks and the lowboy trailers.
Old 10-07-2014, 12:01 AM
bocephus1991's Avatar
If your going to seal it you need to wait abut 6 months for the wood to dry . It's just like building a deck with new treated lumber.
Brian
Old 10-07-2014, 09:03 PM
This thread is kind of a relief for me, I thought I was the only one having trouble with this cheap a$$ treated lumber rotting away.
Old 10-07-2014, 09:12 PM
gmbadgley gmbadgley is offline
Where are you finding it cheap???
"If I can't fix it, I can screw it up so bad no one else can either"
Old 10-07-2014, 09:24 PM
I used thompsons water seal that was honey color, just did it a few weeks ago. I used a pump up sprayer and was done in a few minutes.
Old 10-07-2014, 10:36 PM
No one said it was treated lumber, or green lumber.
