Old 10-04-2014, 05:21 PM
sd38-2's Avatar
sd38-2 sd38-2 is offline
Default 104 carb rebuild questions
I recently picked up my first cub cadet and its a 1968 104. I replaced the spark plug, changed oil, and new air and fuel filters today. The tractor runs good but at high idle it will back fire sometimes. The tractor also sat a lot for the last couple years. I have fresh gas in it but I figured it might need a carb rebuild and cleaning since it has sat for a few years.
The carb on the tractor say Walbro on the side of it and has two adjustment screws. Where can I get a rebuild kit for it? I took the carb off the tractor and took the bowl off. I found crud in the bowl. Engine is a Kohler K241A. I plan on using the tractor to plow my driveway this winter.
Old 10-05-2014, 08:18 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
Just about any L&G dealer should be able to get a kit for you. Check out the sponsors at the top of the page.
Old 10-08-2014, 10:01 PM
sd38-2's Avatar
Thank you!
