Old 10-14-2014, 01:03 PM
bocephus1991's Avatar
Default New pan gasket question
I want to pull the pan back off and check something on my k301 I'm rebuilding. Can I reuse the pan gasket ?
Brian
Old 10-14-2014, 02:06 PM
jimbob200521's Avatar
Nope, generally you never reuse gaskets.
-Ryan
Old 10-14-2014, 02:22 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
If it is not damaged, I would.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 10-14-2014, 02:31 PM
Agreed. It should be fine. If it's wet with oil, then no. Those Kohler gaskets don't do well after they've been wet with oil. For example, recently, I replaced a breather gasket. Don't remember why, but I had to take the cover back off after running the motor for a short time. Used the gasket I had just installed over...... and it leaks. It got oil on it when I removed it. SO, if you keep it dry, your fine. If it's oily, don't risk it. It's a pain to pull the motor to change the pan gasket.
Old 10-14-2014, 03:43 PM
Ok that answers my question! It will prob have some oil on it from assembly . Yeah I sure don't wanna have to pull it again because it leaks! So will get a new gasket. I am getting good at pulling engines now! Thanks guys!
Brian
