My 1250 I bought has newer wheels on the front that don't have bearings. Has anyone used a non-OEM wheel on a cub? If so, what?
The ID is larger than the shaft and I considered using brass bushings to make up the difference. With a thrust bearing on the inside and grease I am hoping this will suffice. Any thoughts or past experience? If I could get some OEM wheels I wouldn't have this problem. |
Put a want ad in the classifieds. I'm sure a bunch of people have extra wheels.
What size spindles does it have? 1 inch or 3/4 inch? That will also be something you need to specify..
Pat Harmon Loganton,Pa 128 Cub Cadet 1200 Cub cadet (Red) LT 1042 Cub Cadet 1200 Cub Cadet 165 Hydro John Deere 1941 John Deere H 1950 David Bradley 5756 1952 David Bradley 57561 Super Power |
Here is the data from the Parts Manual. These are the only wheel rims used on the Quietlines....
![]() .75" Spindles IH 386188-R2 4.00" Rim NLA IH 546730-R2 6.50" Rim NLA IH 384881-R94 Bearing Avail 1.00" Spindles 734-3053 6.50" Rim Avail 941-3002 Bearing Avail
I now have some 3/4" shaft wheels from Patton Acres. What is the bearing replacement for a IH 384881-R94 in SKF,Timken, or Peer?
