Old 10-16-2014, 05:56 AM
kyleb179 kyleb179 is offline
Default Difference in plows?
i've heard their is a difference between a NF plow and an original plow. is this true? if so, what is different about it?
lastly, if the above statement is true, what is involved in making a NF fit an O??
thanks guys
Old 10-16-2014, 06:20 AM
Are you talking about the Front Push Blade...???
Old 10-16-2014, 07:06 AM
yeah the front push blade. sorry. for snow
Old 10-16-2014, 07:36 AM
Well, there are two sizes - 42" and 54".
Then there is Non-Spring Trip and Spring Trip mechanisms.
Then there is the Sub-Frames
* CCO bolt on
* NF bolt on
* NF QA (Quick Attach)
* WF QA (Quick Attach)
The Cub Cadet Original used a 42" Non-Spring Trip blade that bolted on. Unique and hard to find. I don't have any knowledge, if a "NF bolt on" will mount to a CCO without drilling any holes.
Old 10-16-2014, 07:59 AM
thats fantastic information, thank you. so i will be having a difficult finding the plow that actually goes to an O, and it will be much easier to find a NF plow which should bolt right up
Old 10-16-2014, 08:19 AM
This is the orginal Front Blade for the CCO...
Old 10-16-2014, 09:35 AM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
Some of the later ones were spring trip. They had a sleigh runner shaped curved subframe.
I lost track of what I own a long time ago!
Old 10-16-2014, 09:45 AM
Berwil's Avatar
Berwil Berwil is offline
Roland, I believe there are 2 blades for the original. One was a none trip and one that had a trip. The first pic you posted is the original not trip subframe and plow. I believe parts 17 and 19 bolted to the tractor and parts 13 and 19 were the subframe. This plow is more rare and is pretty worthless for actually pushing snow. The second pic you posted is the second plow subframe that takes a standard 42" spring trip blade. I have one of those for my O and it works great.
Bill
Old 10-16-2014, 09:53 AM
Isn't that what I said...??
Old 10-16-2014, 11:45 AM
Berwil's Avatar
Technically, yes. I read it though as a general statement because in the same post you said O blades were only non trip. I believe ihcadetcollecter read it the same way so he mention the later O blade. I was meaning that O blades can be trip or non trip. The first diagram you posted is the non trip blade and subframe, totally unique. The second pic is the "sleigh runner" subframe that takes a regular trip blade, but is still made for the O. Just trying to add some info for the op.
I have seen O trip blades for sale, just not often. I don't know how hard it woudl be to put a NF blade on an O, but I'm sure it can be done with som fab work.
Bill
