Old 10-16-2014, 07:54 PM
NE149's Avatar
NE149 NE149 is offline
Default Kohler K321 Starter Pulley
Need the flywheel pulley with clutch for a Kohler K321... for a 149. Message me here or reply please. I'm in Nebraska. Doesn't have to be new but the set screws must come with it.
Note: This thread was moved because it ended up being instructional. No parts needed now.
~J-Mech
Old 10-16-2014, 08:03 PM
You need a PTO clutch? Or are you talking about the basket pulley? Because the flywheel doesn't have a pulley with a clutch on a 149....
Old 10-16-2014, 08:24 PM
NE149's Avatar
I'm using terminology that I read lol... this thing
Old 10-16-2014, 08:36 PM
Basket pulley. Or, starter/gen pulley.
The flywheel is on the other end of the motor.
Old 10-16-2014, 08:49 PM
NE149's Avatar
Yep I knew that! I've almost got it all re-assembled but the carb and the front end pulleys and such... just trying to avoid buying a new pulley but I'm thinking that is what I'll have to do.
Old 10-16-2014, 08:52 PM
What's wrong with yours?
Old 10-16-2014, 08:53 PM
NE149's Avatar
One of the set screws on the one I got off a collector was screwed in cockeye'd and couldn't be threaded back in...
Old 10-16-2014, 09:01 PM
So..... run a tap through it.
Or, drill and tap a new hole. No need to replace.
NE149's Avatar
What size is the hole? 1/4" Tap is too small, 5/16 seems too big?
Old 10-16-2014, 09:06 PM
5/16" x 18
