Old 10-21-2014, 04:02 PM
Default 2072 getting gas in oil
Hey guys,
My 2072 is getting gas in the oil and when I removed the air cleaner I noticed oil on top of the carb.What's That about? Is it a bad fuel pump or bad needle and seat in the carb? Thanks.
Old 10-21-2014, 05:18 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Sounds like it is time for a new fuel pump and maybe a breather valve too.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 10-21-2014, 05:26 PM
j4c11's Avatar
j4c11 j4c11 is offline
Check the carb, I had the same issue and the carb I had just rebuilt 4 months ago was full of brown gel-like beads of crud from moisture in the fuel. But it could also be the needle valve is not sealing. If that's not it maybe the fuel pump.
Old 10-21-2014, 05:30 PM
Ok, I figure the same thing, thanks guys.
Old 10-22-2014, 03:41 PM
Am I better to get a carb off a kt17 or rebuild this one? It's a walbro.
Old 10-22-2014, 03:57 PM
Nick, you can also put a #26 carb on it.
Old 10-22-2014, 05:45 PM
I second that motion!
Old 10-22-2014, 05:58 PM
jimbob200521's Avatar
I think the consensus is; ditch the Walbro.
-Ryan
Old 10-22-2014, 06:25 PM
Thanks Allen, what about the linkages?
Old 10-22-2014, 06:26 PM
Probably have to swap the throttle shafts.
