Old 10-22-2014, 08:28 PM
garnold's Avatar
garnold garnold is offline
Cool to hear about them working ok in bad weather. Hahaha funny about the front weight :-)
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 10-23-2014, 11:52 AM
Steve149's Avatar
Steve149 Steve149 is offline
Originally Posted by mickb72 View Post
I have a new one sitting one the shelf waiting, too bad my 2 year warranty has run out. I've heard those remotes burn out quickly then you have to make your own switch. The other day a friend used a bigger HF winch to pull a dead chevy 4x4 onto a trailor. He'd been waiting for a sale on the winch.($279 i think) It pulled that heavy truck right up, only trouble was the cable didn't wind up straight and bound a couple times. That cable looked like 3/8", plenty of power may need some reengineering. Mike
I noticed in the ad that there was a fairlead on the front of the winch...did this come with it? From my jeep experiences that is important to keeping the cable straight!
PS...Sam mine is on the way as well ! Not sure what its use will be but setting thinking about is I will come up with something!
Old 10-23-2014, 04:23 PM
Yep they come with the fairlead. I have 3 of them sitting on the shelf if any of you need one let me know.
Old 10-24-2014, 08:22 AM
mickb72 mickb72 is offline
Default cub
Come to think about it there was no fairlead. We had to roll it out and back a couple times. It had a couple spring loaded guide bars across the top and back. A plastic control box was mounted on top of these bars with brackets and retainer screws in the back. It would ball up and pop the bracket loose and the spring loaded guide roller bar. Needed a BFH. Have to ask him about a fairlead. Mike
Old 11-29-2014, 07:23 PM
garnold's Avatar
Looks like this little guy is on sale again...
http://www.harborfreight.com/2500-lb...l_s1042_c4814d
73 WIP
75 WIP
Old 11-30-2014, 11:34 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Thanks for the update Gene!!
I went ahead and pulled the trigger this time!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 11-30-2014, 12:01 PM
Hmmm....wonder if these are offered in a 110V application?
Need one for raising a heavy overhead loft stairway,
Any ideas??
Old 11-30-2014, 12:14 PM
darryljs's Avatar
darryljs darryljs is offline
Any ideas??
Just attach the 12v winch to a 12v auto battery.
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
Old 11-30-2014, 12:19 PM
I just want to caution you guys, these things have a time lag from when you release the button on the remote to when it actually shuts off. Not the greatest when it comes to precise control. Be careful.
Old 11-30-2014, 01:02 PM
jimbob200521's Avatar
Just did the same here. Didn't do it last time but figured with how many times around the property I've wished I had something to pull a tractor up on a trailer, lift something in the shop, pull something in the yard, etc I could find 1001 uses for it. Thanks guys for posting this again
Edit: Anybody end up using these mounted in the garage to help lift engines out of Cubs or anything like that? I know they aren't overhead rated but for pulling an engine or lifting a deck or something; I don't see why that wouldn't work fine.
-Ryan
