Old 11-09-2014, 12:48 AM
garnold's Avatar
garnold garnold is offline
Check out these
http://onlycubcadets.net/forum/showthread.php?t=4644
http://onlycubcadets.net/forum/showthread.php?t=4646
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 11-09-2014, 05:45 AM
donnelly.me's Avatar
donnelly.me donnelly.me is offline
According to everything I have read, your 149 should only go 7 mph at full throttle. If it is faster than that, I also suggest checkin the max rpm's. K241 should have a max throttle speed of 3600 rpms. I was messing with mine once and had the rpms too high. The tractor was screaming fast! However, I got lucky I don't blow it up. Check rpms. I doubt anyone messed with the rears. Mark
1973 Model 149
42" Snow Blade
John Deere X360
John Deere 10 cu Poly cart
Squire Applegate 5HP recoil start
Old 11-09-2014, 07:30 AM
http://www.youtube.com/watch?v=mKhQeXfqxUs
According to this guy, pretty frighteningly fast.
Old 11-09-2014, 08:14 AM
NE149's Avatar
NE149 NE149 is offline
I just did a filter and fluid change on my 149... and it still ran slow going forward but faster backward. Well I finally decided something more was up, so I started looking at the linkage. Someone installed a governor bolt to keep it from going so fast forward. Even at an idle my 149 hauls ass. I bet it goes faster than our Deere Zero Turn going forward, no joke. So yours isn't an oddball for speed.
Old 11-09-2014, 08:58 AM
Bob95065 Bob95065 is offline
Watching that video I left so sorry for that over-reved Kohler. Just when I thought it couldn't get worse he went downhill which could only increase engine speed.
Old 11-09-2014, 09:12 AM
Rob C's Avatar
Rob C Rob C is offline
I don't, but I'll get one. Does anyone know a manual that refers to the governor?
Old 11-09-2014, 09:27 AM
dbuck dbuck is offline
Smile
I think someone had better be checking the rpm's on that CC. Before they gernade the engine. My 149 moves along at a pretty good clip, but no where near as fast as that machine.
Old 11-09-2014, 09:36 AM
Rob C's Avatar
Thx, that is exactly how fast mine is going!!!! LOL. I will work on getting a RPM guage and screwing with the govoner later today..
Thanks all. You've been very helpful. I was thinking theres no way this thing should move like this, but its my first cub,, so I had no idea..
Old 11-09-2014, 01:22 PM
snoel's Avatar
snoel snoel is offline
My 149 was too fast, but now it's just right. I actually put a bolt through the cam-slot, to limit travel. I have nowhere around my place, with enough smooth or long enough space to use that much speed. And, with ground engaging equipment, it was even dangerous , because it was too easy, to push the shift lever too far, when changing direction. I now have a good max plowing speed, and a decent travel speed in transport.
ps; I only run aprox 1/2 RPM, as I don't mow with it.
Steve
Old 11-09-2014, 03:28 PM
Rob C's Avatar
I agree. Thats something I will definately be doing. My wife will sometimes mow the lawn with it.. I don't need her barreling into anything..lol
