Old 12-04-2014, 10:35 AM
Great pictures of the Cubs on Firewood duty guys
Old 12-04-2014, 07:03 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Nice pics guys.
Thanks, Sam and Diz!!
Today, I moved the mower decks down to the barn for winter. Also cleaned up in front of the shed with the Super and cleaned up some sticks and whatnot and killed it with fire and adult beverages!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-04-2014, 09:42 PM
Nice work Shrewcub
Great pictures
Old 12-05-2014, 10:20 AM
Shrewcub's Avatar
Nice work Shrewcub
Great pictures
Thanks, Diz!!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 12-05-2014, 06:17 PM
cub123's Avatar
cub123 cub123 is offline
Finished putting a hydro fan on the 149 and decided to change the oil, then when filling the oil I hear something running on the ground, take a look and the aluminum oil pan has cracked around the drain plug So my oil change went from 10 minutes to 6 hours pulling the engine and swapping a cast iron oil pan, decided to pull the grenade gears while I was in there, they were pretty loose. It did make greasing the steering box easy though.
Old 12-06-2014, 08:59 AM
Tony h's Avatar
Tony h Tony h is offline
Ran out this morning , between the rain drops to get the Rebuilt Hydro Release valves back in. Buzzed Tug around the yard all all RPMs and speeds, reverse too.. Valves are all nice and dry. While some Covers were off I greased and oiled some of the linkage.
Thanks MACHTECH
If I can't fix it , it must not be broken
Old 12-06-2014, 02:54 PM
titleist1 titleist1 is offline
Hydrostatic oil & filter change on the FIL's 2182 SGT today as well as my 2155. Even with the workshop heated up by the coal stoker and the oil warm it takes quite a while to ease all those quarts of oil into that skinny little fill hole on both tractors.
I don't think I'll be doing anything that requires patience the rest of the day!
I was hoping to change the engine oil & filters as well but ran out of time so I'll probably mess with that tonight since I left the stoker running.
Old 12-10-2014, 05:28 PM
cub123's Avatar
Got wood with the FEL again, sure makes things easy
Old 12-17-2014, 04:19 PM
cub123's Avatar
Used the FEL again today, time to dig up the septic tank covers! It did better than I expected, the dirt was pretty hard with a lot of rocks, didn't even spin much.
Old 12-21-2014, 09:01 PM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Nice FEL. We had the 2182 out today to help with splitting firewood.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
