Old 12-14-2014, 08:35 PM
There is no comparing a gear drive and a hydro.
Old 12-14-2014, 08:40 PM
GTKid GTKid is offline
Ok I might be willing to sacrifice hydro lift if the 3spd would be that much better.
Only a 1282 with ~700 hrs(serial 729357)...
Just red and black and ain't goin back!
Old 12-14-2014, 08:47 PM
Still gotta get the power to the rear, and then to the ground. If you are successful, you'll still tear up the rear. You'll have to build it up to handle it. That'll cost at least a grand. By the time you get a clutch that will hold, then bearings and retainers that won't crack, heavier axles, shift forks......
It's one thing to build something cool to look at. It's another entirely to make something that actually works.
Old 12-14-2014, 08:51 PM
Hmm I'll think about it
Old 12-14-2014, 09:00 PM
If that motor is bad in your 1282..... cheaper to rebuild it. Or find another motor. Are you sure it's bad and not just come unbolted?
Old 12-14-2014, 09:04 PM
I wasn't looking to put a ton of money into it at once, more looking for a fun winter project, the motors def knockin pretty bad, she uses a lil oil too
Old 12-14-2014, 09:42 PM
Well..... if that's the case I think your going the wrong way. Cheaper to fix it that do what your doing. You sure it's the motor...... Seen more than one where the engine wasn't bolted down and created a knock.
