Old 12-14-2014, 08:13 PM
jimbob200521's Avatar
Default Any 1340 owners on here?
I found one somewhat local for a good price and am debating picking it up. I'll be up front, my thought is pick it up cheap now, give it a good tune up (fuel line, clean it, tank bung replacement, oil change, trans fluid change, etc), then when spring comes around sell it. Or it'll grow on me and I'll keep it, who knows
Anyway, whether I keep it or not, what are your thoughts on it? I don't see a lot around so would this be a rarer MTD Cub? Anyone here have one? General thoughts on it? Thanks guys
-Ryan
Old 12-14-2014, 09:18 PM
GTKid GTKid is offline
Looks like a 1440 with a Command motor on it, I like it a lot better then the 1440 with the briggs
Only a 1282 with ~700 hrs(serial 729357)...
Just red and black and ain't goin back!
Old 12-15-2014, 06:49 AM
Doesn't float my boat. They have the rubber engine mounts like the QL's and 1210's. I had a 1210, ended up repowering it with a Vanguard.
Old 12-15-2014, 08:42 AM
Hmm didn't know that Do you know if they are the SAME ISO's that were used on the QL; as in could I replace them with the solid mounts sold by Jeff?
-Ryan
Old 12-15-2014, 09:52 AM
Not sure, check part numbers on parts tree or cub.
Old 12-15-2014, 10:25 AM
Duh. Sometimes it's easier to ask with looking, guess I am guilty of being a bit lazy on that one
-Ryan
Old 12-15-2014, 10:27 AM
Partstree shows them as different. Hmm...could be challenge. I like it!
-Ryan
Old 12-15-2014, 10:45 AM
yeeter yeeter is offline
If flipping, I would stick to the known popular/rarer models. Just the fact that you didnt know much about it means its not at the top of the popularity list. Might not sell so easily.
On the other hand, if you put a snow blade on it and it runs well and its early Winter and you price it well below a walk behind blower... doesnt much matter the tractor, someone will buy it.
Old 12-15-2014, 11:09 AM
My guess is that it wasn't a very popular model, they only show as being made in 90 + 91. The 91 price was reduced by $582.00 Maybe it's a rare tractor, don't know.
Old 12-15-2014, 11:55 AM
From what I know of it, it's just a Cyclops with a 12.5hp Kohler in it with, as Sam pointed out, the rubber mounts. Other than that, standard equipment for the time/series. Just wanted to see if anyone here had one as search results were slim.
-Ryan
