Old 12-18-2014, 12:26 PM
Default 1811 governor
I have a chance to pick in a beautiful 1811 with a rebuilt engine in it, the guy that built it didn't replace the governor and now its having some issues. My question is how far apart do the twins have to come to replace the governor? I've never messed with one of these twins and I just wanna be sure what I'm getting into before I make a deal.
Old 12-18-2014, 12:34 PM
Completely.
Old 12-18-2014, 12:37 PM
Completely.
You supposed to lie to me and make it sound easy. I assume the governor problem stems from a plastic gear being stripped just like the older singles?
Old 12-18-2014, 12:48 PM
Yep.
You sure it's not just an adjustment issue?
FWIW, you can see the gear through the oil fill.
It's the same governor assm as the "K" series.
Old 12-18-2014, 12:52 PM
It runs wild with no controllability from the throttle. I'm not sure of anything but just wanted to know about the worst case scenario.
Old 12-18-2014, 12:58 PM
Ok.
Had a guy I helped on another forum the other day with the same issue. Adjusted the governor and it fixed it.
Now you know worst case.
Old 12-18-2014, 01:16 PM
Thanks for the info. I'm really hoping to get this tractor as its in beautiful condition and it currently sitting at a friends house that has over 200 cubs that he sells parts off of, its just way to nice to turn into a parts tractor over something like a bad governor.
Old 12-18-2014, 01:27 PM
I had a Mag18 that the gov took a dump but it punch a hole in the block. Engine still ran good but as with the one your talking about you couldn't control the RPM's.
Old 12-18-2014, 01:29 PM
Did it have the plastic gear? I'm pretty sure they all did.
Amazing that the plastic gear didn't just smash when it hit the side. Must have hit it just right. I've not had one that did that, but your not the first person I've seen that that happened to.
Old 12-18-2014, 01:41 PM
Jon
I didn't open the engine, my guess is one of the flyweights did the damage. Probably just happened to end up in a place the 2 things couldn't fit at the same time. Only way I could control the RPM's was to pull the choke. Repowered that tractor with a CH22.
