Old 12-20-2014, 05:52 PM
johnpded johnpded is offline
Default 2182 Cub Cadet with a 4th blower
I'm having trouble with the blower it keeps throwing the belt. I changed 2 of the 3 pulleys and the mounting bracket that holds the tension pulleyes and I changed the spring. Any ideas?
Old 12-20-2014, 06:09 PM
If you can post some pics someone may see a problem.
Old 12-20-2014, 08:00 PM
What belts are you using...........??????
Old 12-21-2014, 05:01 PM
Using mtd belts from a farm supply cub cadet dealer. I'll post pictures a little later
Old 12-21-2014, 06:01 PM
What do you mean "the 4th blower"...???
Old 12-21-2014, 07:10 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
My guess is autocorrect didn't like 450 or 451.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-23-2014, 12:22 AM
You're right auto correct
Old 12-23-2014, 12:28 AM
Old 12-23-2014, 10:44 AM
jimbob200521's Avatar
I don't have enough experience with the 450/451 blowers but something looks off with that belt tensioner. I have the same sporadic issue with mine (the couple times I dry ran it ) the belt will hop off the PTO when engaging it. I just pop it back on and I'm good to go but still weird none-the-less. I will be following this thread.
-Ryan
Old 12-23-2014, 10:59 AM
Looks like the belt may be upside down on the lower pulley in the second pic. May be just they way I'm looking at it. Don't know if you put it on that way or if it flipped over.
