Old 12-26-2014, 08:22 AM
IROC-Z28 IROC-Z28 is offline
Default My First Super 2182
Hey all,
New to the forum, excited to see more talk about super cubs than anywhere else. I picked up this 2182 a few days ago for 1200 bucks, around 380 hours of it. And a 54 inch deck (I will be getting a haban). Deck looks rough but is solid. Kubota idles like a sewing machine. My plans are to clean it up, do all the proper maintenance, and get it ready to mow. I have a 140 h3 I will be using for plowing snow so this will be designated for mowing. Did a quick compression test an all three cylinders scored between 150-160 psi so I think I'm good to go!
Old 12-26-2014, 08:36 AM
Group_44's Avatar
Group_44 Group_44 is offline
2082 and 2182.......not quite the same animal. But welcome to the forum. Looks like a nice Super Cub. Look at this link should get you started :http://www.onlycubcadets.net/forum/s...ad.php?t=33244
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 12-26-2014, 08:49 AM
Ha what a mess 2182 I appologize.
Old 12-26-2014, 08:59 AM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Congratulations on the new to you machine. I just recently picked up a 2182 also and I love it so far and I'm sure you will too. You will love that little Kubota.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 12-26-2014, 09:47 AM
Fixed the 2082/ 2182 for you. Welcome to OCC. You got a good one from the sounds of it. You may find some of this info useful.
Old 12-26-2014, 09:48 AM
Thanks Sam, I appreciate it
Old 12-26-2014, 09:49 AM
Thanks Diesel
Old 12-26-2014, 05:11 PM
Just ordered the xtreme sgt rear end brace. Hope to install that as soon as it comes in. Will be re-wiring the entire tractor as well. Hoping to get a simplified wiring schematic to eliminate safety's. Stay tuned.
Old 12-28-2014, 12:33 PM
Well started in on the rear end today. Removed the rear hitch plate. Everything was covered in oil and grime.
Old 12-28-2014, 12:34 PM
Leaks from who knows where, or maybe just grass clipping dirt and a little oil.
