Old 12-29-2014, 08:41 PM
IHinIN IHinIN is offline
Split the 129 to replace a bad cork gasket and replaced the trunnion springs and pins. I pulled the top cover plate off and replaced the gasket since it was seeping around one corner. Refilling the rearend is much quicker with the top cover off. Got the rearend back in. I'll get the fenders and seat back on tomorrow.
Old 12-30-2014, 05:51 AM
nikster's Avatar
nikster nikster is offline
Great work & lookin goooooood!
NIK,
Old 12-30-2014, 04:42 PM
Nice work IHinIN
Good looking 129
Old 01-01-2015, 02:58 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Cool I hate potholes!!
The 129 looks great, Adam!!!
I got the 782 out to fill a few holes in the driveway and cover some muddy spots. I also wanted to see how the ags did on the front. I really like them!! Thanks sawdustdad for your opinion!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 01-01-2015, 07:53 PM
Thanks guys!
I got the 129 back together and fingers crossed, no more leaks.
Now, I need to figure out why it doesn't seem to be charging. I recently rebuilt the S/G so I'll test it first and if it checks out I'll replace the voltage regulator. All of the wiring is new and grounds checked good. The ammeter needle bounces around like crazy so I wired around the gauge to eliminate it as the culprit. I pulled the cover off the V/R and the contacts don't move while it's running. Not sure if that's because the regulator is bad or the S/G is not working.
Travis, the 782 looks good with the blade and box scraper on. Do they both raise and lower together or is the rear lift somehow independent?
Old 01-01-2015, 08:26 PM
Shrewcub's Avatar
Thanks Adam, they both work together for now. Today I had the front blade locked up with the cam on the right side. Maybe one day I will separate them. I will try to
remember to get some pics tomorrow when I try out the 54" Xtreme blade on the back, because we all know
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 01-01-2015, 08:34 PM
chris hall's Avatar
chris hall chris hall is offline
cant wait to see that. the tractor is looking good btw !!!!!
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
Old 01-02-2015, 02:55 PM
Shrewcub's Avatar
I just tried out the Xtreme 54" sleeve hitch blade. It did a good job leveling out the wider holes on the driveway. It would have done better if the ground was drier, but I don't think that will happen until next summer the way things are looking.
I got the drawbar weight box free with the 122 I bought. He also gave me a homemade lead weight that fits inside. I just took the bathroom scale out and it weighs in at 104 lbs. I think that would be a bit much for the blade, hence the old bar weights I have in it. If there was more gravel on the driveway, I don't think any extra weight would be necessary.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 01-06-2015, 02:16 PM
PaulF PaulF is offline
Pushing a bit of snow for the first time this year. Its quite obvious I need to get some more weight on the back of this rig...good thing the snow was really light and powdery.
Paul F
Infantry Veteran
Original...100/123/147 custom...149 FEL...782D...1282...1864...2182G
Old 01-06-2015, 02:34 PM
jimbob200521's Avatar
Great looking machine, way to represent Illinois!
-Ryan
