Old 01-01-2015, 01:59 PM
yeeter yeeter is offline
Default Worn dash edge
Whats your favorite repair for a plastic dash edge that wore through from where the hood vibrates against it?
Old 01-01-2015, 02:11 PM
Rough it up and fiberglass it. Or, plastic weld it.
Old 01-01-2015, 02:52 PM
I do have some marine epoxy resin.
And epoxy glue.
And there is always the super glue mixed with baking soda trick.
In the 70's there was a toy called 'spin welder'.
Or I could put my soldering gun on a variac and melt something into it.. maybe make a mess.
Old 01-01-2015, 03:48 PM
I use JB Weld but you gotta get it feathered out good because it is a PIA to sand. Here are a few I've done.
This one is typical of the diesels. I used tape on the back side where the hole was.
Several coats and some sanding.
Then I sprayed a little paint and it turned out pretty good.
This one was in 2 pieces. I used fiberglass on the back side and JB on the front. It still looks good today.
I now put a piece of Armaflex insulation between the dash and hood when I'm working my tractors to keep them from wearing.
