Old 01-11-2015, 08:39 PM
jubilee's Avatar
jubilee jubilee is offline
Travis- My new Tru Powers from Amazon are 4 ply.
___________________
Jim
782 w/Command 18,
1862 not running;
IH 42 inch blade; off brand cart
Old 01-11-2015, 09:07 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Thanks Jim. I dont think I will be able to tell the difference between them once they are mounted. Now I need to figure out which side I will abuse more before I mount them.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 01-11-2015, 11:17 PM
Berwil's Avatar
Berwil Berwil is offline
I think the 8 ply needs to go under your wallet.
Bill
Old 01-12-2015, 12:20 AM
Shrewcub's Avatar
Bill
Bill! It won't be necessary after I call Xtreme this week.It's going to loose some weight!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 03-14-2015, 07:28 PM
Shrewcub's Avatar
The rims had a few weeks to fully cure in the house and I was bored with the rain. So I brought them inside and mounted them. Sat the tires in front of the wood stove for a while to make them as pliable as possible. The 4 ply was pretty easy, the 8 was a PITA!! At least I learned on the 4 ply to do it from the back side! You can see the chips in the 4 ply on the left. Monday I will play painter with the 3 point and a bunch of other stuff, so I will mask the tires off and at least keep them from rusting.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 03-15-2015, 12:02 AM
You'll get that on those big jobs Don't look the worst.
Is there a noticeable difference in size or overall looks between the two mounted up?
Old 03-22-2015, 03:58 PM
Shrewcub's Avatar
Finally got to play painter yesterday. Today I seated the beads. Here's a side by side with 15 psi. Tomorrow I'll go get about 25 gallons of Rimguard and get to work on the rear and puttting the Cat 0 put on the super.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 03-22-2015, 07:43 PM
20 gals is plenty.
Old 03-22-2015, 08:11 PM
Good to see you put your new rubbers on correctly,no accidents that way.
Up to 534 and counting...
Old 03-22-2015, 08:26 PM
Shrewcub's Avatar
20 gals is plenty.
Thanks Sam! I'm sure you're right. I forgot to factor in how much smaller they are than the Goodyear Balloons that are on the Super. I did get 12 in each one of those.
Thanks Lew, I think!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
