Old 01-24-2015, 03:57 PM
Very lucky man, if that flywheel came apart he could say goodbye to his feet. Ya just can't fix stupid.
Old 01-24-2015, 04:41 PM
gt383mag's Avatar
gt383mag gt383mag is offline
wasnt his feet had his 10 year old kid on it
Old 01-24-2015, 05:08 PM
Good thing I wasn't around, I would have pulled the kid off that thing then beat the crap out of the sperm donor, can't call him a father because no responsible father would put his kid at risk like that. Rant Over!
Old 01-24-2015, 07:02 PM
gt383mag's Avatar
stupidity is no excuse but this is the way the guy got it and i would assume he thought it was safe because the previous owner used it this way... some people just dont know about engines. im pretty sure i can put gov. stuff back in it. the guy i got it from said it dont have original crank and has high compression so much starter struggles badly with it and it has race fuel in tank. i have a really nice 1440 sittin here got without motor and rear end is locked up (when we tried to move it under its own power it would kill motor both forward and reverse) we pulled the motor for a nice 1211 we have. kinda thinkin since the 1440 has manual lift anyways it will make a good home for the stick trans outta this puller.
Old 02-13-2015, 04:05 PM
gt383mag's Avatar
well i got the motor apart not too bad one bent push rod witch nicked the cam lobe but look what the guy did to the gov and compression release cams are on e pay for 29 bucks and the gov lever is still available so i think its gonna be ok
not so sure i understand why he woulda welded the gov and the comp release i would think if you just unhook the lever the gov is inop
Old 02-13-2015, 05:03 PM
Take the OP's tools away before he hurts someone.
