Old 01-29-2015, 01:45 PM
Leadslingingdaddy's Avatar
JD has a mid mounted pump.. Checkout WFM site and search tillers...
Torch and welder anything can be made!!
Old 01-29-2015, 01:49 PM
sbauerz28's Avatar
Originally Posted by Diesel Krazy View Post
Here is a pic of my hydraulic tiller. It mounts on a sleeve hitch. It would be a great starting point if you wanted to make a setup for your Cub. Make a mount for a pump off the front Pto and a bracket can be made to hold the oil resivuar on the front of the tractor to double for front weight to help offset the rear weight of the tiller. These tillers can be found for reasonable prices.
That is a nice set-up, but I think the JD tiller would be easier to convert to a real tractor, like a Cub. LOL
The JD uses a pump that mounts under the tractor and has a belt that runs to the PTO. The oil tank is on the tiller. It holds 4.5 gallons from what I've read. I was just going to weld the mounts on the tiller and mount it on the 3pt.
Old 01-29-2015, 03:16 PM
plus you do have to remember that the case's, although perhaps arguably the most hydraulically capable tractors (oem) they also have their own oil cooler..so to run a case implement on another type would be an issue.. i think you would need to put some sort of cooler on it, or available on the tractor...even an old intercooler with a fan blowing across it would probably work...
Old 01-29-2015, 03:23 PM
Here is the cat 0 hydraulic Cub tiller. It is a model 190-004-100. I hear that they work awesome, will fit your cat 0 hitch and you can run the tines forward or reverse by the lever on the unit mounted spool valve(or whatever that handle do-hickey is). These are for the 3000 series tractors and use a shaft to turn the mid mount pump but you could mount the pump up under the front pto and use a short belt. I just missed one up in eastern Pa for $500. They hold 4 or 5 gallons of oil and it looks like they use the tiller shell as a heatsink.
Old 01-30-2015, 07:48 AM
I know where there is a 400 tiller.
I was looking hard for one of those until I found my 982(6) donor with all the goodies except PS....
They are hard to find but would do the trick if all you have is a sleeve or 3pt hitch.
All self contained tiller....
