Old 01-29-2015, 07:57 PM
Tankman's Avatar
Tankman Tankman is offline
Default Sundstrand or an Eaton?
Workin' on the '95 CCC 1641, we like the Cubbies!
Is the hydro on this Cub a Sundstrand or Eaton?
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 01-29-2015, 08:04 PM
In both generations of the 1641, the transmissions were made by Hydro Gear.
Old 01-29-2015, 08:05 PM
Yep Hydro Gear as Dr. Roland said.
Old 01-29-2015, 09:54 PM
Tankman's Avatar
Oh my. Thanks for the info. Might Dextron III be OK?
I downloaded a Hydro Gear manual, perhaps not correct, but manual says "engine oil."
http://www.hydro-gear.com/main/docs/...uals/pumps.pdf
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 01-29-2015, 10:15 PM
Yes. It will be fine. I will say, I ran it for a while and ended up changing it out. I think it's a little too light of oil. In the winter when plowing snow (and using the lift) I thought it whined a lot more. May have just been my imagination.... No damage will occur, but I switched back to a hy-tran oil (Not IH Hy-Tran, just a hydraulic trans oil.)
Old 01-30-2015, 12:43 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I have Dex VI in my 782 and it seems to be the quietest hydro I have. Maybe it's a coinkydink, point is it won't hurt anything.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 01-30-2015, 03:18 AM
It may have just been my imagination. I will add..... it was below 0 during that time.
Old 01-30-2015, 07:01 AM
Tankman's Avatar
Thanks J-Mech and all.
Guess I've never heard of Hydro Gear before now.
The manual I downloaded from their website.
My library is growing rapidly. I purchased a number of heavy duty plastic envelopes some time ago. Clear plastic. I use a staple gun to pin 'em to the workshop wall, print and put papers in them with the cover showing.
Put the Cub manual in one, cover front 'n center, attention! Huh!.
There I go again, once a Jarhead, always a Jarhead.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 01-30-2015, 08:52 AM
Just my 2 cents on the ATF oil deal. I had one hydro gear pump that was given to me a couple years ago, it was supposed to be bad. The PO had filled the trans with ATF. Took it apart and it had globs of stuff that looked like pink Crisco all over the insides. My guess is the ATF and the Hy-Tran didn't like each other. If it was my tractor I'd play it safe and stick with Hy-Tran or something that is compatible with Hy-Tran unless you have the rear torn down and totally cleaned out.
