982 Onan 984 Onan 986 Onan 1572 Kubota D 600 diesel 1772 Kubota D 640 diesel 1872 Kohler Mag18 1912 Onan 1914 Onan 2072 Onan (early 2072's had Onan's) 2072 Kohler Mag 20 Cyclops 1782 Kubota D 640 diesel 1882 Kohler Mag18 2086 Kawasaki FD620D 2082 Kohler Mag 20 2182 Kubota WG-600 gas 2084 Kohler CH20 2284 Kohler CH22
What they said.!!!
DragonCub,
Nice snag my friend! Three point and rear PTO to boot. Cool! Don't delay on the tiller. They are harder to find and pricey. Snap some pics of it after ya pick it up.
Josh Diesel Cub Cadets........... |
Yesterday I got a chance to mess with it. I have a bad pto switch so I had to bypass it to get it to turn over. The carb was no good so I pulled the carb off my 782 and it fired right up runs good but have an issue. The front seal on the hydro pump leaks. Guess I'll pull all that apart and see about getting a new seal Monday.
Well it's been awhile but I got it running and mowing. I had to get a new ignition switch, replace the seal on the hydro pump and while it was apart I noticed the bushings on the drive shaft were destroyed so I ordered some new ones and installed them. Since then I have mowed with it several times I have to say out of all the mowers I've owed this 60" haban deck is the best mowing deck I've mowed with. Now I'm going to start fixing the worn out parts, deck bearings, tie rod ends things like that. Also the PO put a tube in one of the front wheels and it rusted it pretty good so I'll have to cut out the bad spots and repair it with one of the old rims I've got.
