Old 02-06-2015, 10:06 AM
BassBlaster BassBlaster is offline
Default Lets talk tires
So the 1864 will need some new shoes. Looks to have the tires that came with it in 94. Seems ags and turfs are priced pretty similar. Ive looked around and it appears they are also similar in price.
Through my research, Iv decided that Id love to have set of Tru Powers on the rear and a set of v61's up front. That combination just looks cool!! Sadly this tractor dosnt need to look cool, it needs to serve a purpose. It needs to be a beast of a grass killing machine and it needs to push snow in the winter. My yard is relatively flat with one rolling hill. I do mow one ditch that is fairly steep but its steep enough that I only mow it when its completely dry. I should also mention that in the spring we get lots of rain and I have one small area that holds water and stays relatively soft. Not soft enough for the tractor to leave ruts but soft enough that when I mow it wet, it leaves muddy tracks on the grass. As for pushing snow, my driveway is blacktop and flat with the exception of a very small incline near the street. Its old blacktop that's chipped up and cracked up and I wouldn't hesitate to run chains on it.
Looking for opinions as Ill be ordering new tires once I get her running good. If ags are suggestion, Im going with the combo above. If turfs are suggestion, please give me suggestions. Ive aways purchased the cheap Carlisle turfs at WalMart which are junk in my opinion. Thoughts???
Old 02-06-2015, 10:51 AM
Since you have a flat lawn and also need to plow snow I'd use turf's on the rear because they work better with chains for snow plowing. This is a link to tire dealers. Miller seems to be very popular with our members.
http://www.onlycubcadets.net/forum/s...ead.php?t=4658
Old 02-06-2015, 11:05 AM
yeeter yeeter is offline
I have found when pushing a pile of snow with the blade at an angle, the lawn tires on the front slide sideways easily.
So I have a pair of V61's that are going on it, and hope they will help hold the line a bit better.
Old 02-06-2015, 11:18 AM
The v61s should work good on the front for both application. As Sam said I'd go with turfs in the rear as ags may tear up the yard where its soft and I also prefer chains on turf tires as they apply pressure to the chain more evenly.
Old 02-06-2015, 12:03 PM
Thanks for the replies guys. Anyone have a recommendation for the rear turfs? Like I said, Ive used the cheap Carlisle turfs that Walmart sells and I don't care for them. Always bought them because they were cheaper. I have no problem paying more for better quality though.
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I agree with the others. My 1864 still has the original tires on it. Shortly after I bought it I loaded the rear ones with washer fluid. It made a huge difference, I never spun a tire when mowing again. Since then I did add one set of 26# IH weights, mostly for looks, but they do help.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-06-2015, 12:13 PM
The Turf Masters don't look bad. The ones Ive used and don't care for are called Turf Saver.
Old 02-06-2015, 12:19 PM
Anyone have experience with these?
http://www.amazon.com/Carlisle-All-T.../dp/B005O5NAFI
Old 02-06-2015, 12:29 PM
j4c11's Avatar
j4c11 j4c11 is offline
I have TurfMasters on my 1450, no traction issues and they don't tear up the lawn, and my lawn is on an incline. Should have no problem on flat.
Old 02-06-2015, 02:10 PM
Originally Posted by BassBlaster View Post
I have a 1641 with a set of ATV tires on it. The sidewalls are very soft and the tractor does a lot of rocking and rolling over uneven surface. They ride pretty smooth though.
I prefer turf tires, period. The AG's seem to ride too rough and tear up the grass.
