Old 02-07-2015, 03:20 PM
budscub's Avatar
budscub budscub is offline
Default Its alive!!! 1450 w/dual hydraulics
My newly acquired dual hydraulics 1450. I bought this tractor just before Christmas. I ran across this on Craigslist and the dual hydraulics caught my eye. I hadn't had time to mess with it any. PO said it had a bad hydraulic leak and had been sitting for some time. Well with today's beautiful weather I couldn't resist to fool with it. Added hydro oil, put in a little go go juice, booster cables and...... nothing. Jumped directly to starter, ah ha we have rotation, but no bang bang. No problem, hot wire to coil, nope ain't gonna do it. I pulled plug no spark. Okay no problem pull point cover, hot feed to coil jump points with screw driver, it was the prettiest blue arc of life you have ever seen. Cleaned points re-install plug, presto change O, badda boom and badda Bam she hit faster the a politician on the campaign trail. This ole man is all grins. No smoke, no abnormal noise. I am thrilled.
So as for the hydraulic leak I just knew it was the automatic check valves but no, the drive shaft is wobbling something awful, looks like a little seepage around the pump shaft. No problem, so now I will do cradle modification, new Iso's correct the drive shaft, replace the pump seals. Then I can play Ugh I mean work on it before giving it the "Restoration" treatment.
Oh I know the drill, Photos to follow.
Have a great day All..
BudsCub.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 02-07-2015, 03:37 PM
presto change O badda boom and badda Bam is a good thing.
Old 02-07-2015, 03:49 PM
budscub's Avatar
Yes Sir, Sam it is especially when it is unknown. Still grinning, It is sitting out there idling as I tyoe this.
My garage is a total wreck right now and I should be running drywall mud, but hey I can do that when the sun sits. Just enjoying that K321 rumble at the moment. I have been enjoying this forum just reading and Listening to what everyone has to tell.
Gary
1969 125 42"
Old 02-07-2015, 05:34 PM
cadzag72 cadzag72 is offline
It's so satisfying bringing one back. Nice work!
Ian
Old 02-07-2015, 06:22 PM
You are gonna LOVE that front hydraulics if ya can find a hyd angle blade for it this or next winter!!
Just don't leave that ;ol girl sit out in the weather so's the dual handles get all rusted up and stuck. The last one I bought had been outside like forever and I cannot get 'em unstuck short of breaking out the gas wrench.
Enjoy!!
The 1450's are great rigs!
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Nice work, Gary!! On the 1450 and the post. That was fun to read!!
Now
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-07-2015, 06:31 PM
good for you!!! im excited to see this dual stick....
Old 02-07-2015, 07:53 PM
Originally Posted by JLM78 View Post
glad some one got it not a dealer .That guy was Desperater for money that had that
"That guy was Desperater for money that had that" Please explain what you said?
Old 02-07-2015, 11:20 PM
budscub's Avatar
Not really, he had a 125 also but I already have one. He was just reducing his inventory.
Gary
1969 125 42"
Old 06-19-2015, 09:36 PM
budscub's Avatar
Default finally a pic
Well here is a photo of 2 of the boys, 1969 - 125, 1978 -1450 w/dual hydraulics. Finally got a little time and ambition to tinker. Found the main hydro leak to be the brake piston. Did cradle mod, moved top mounts to the bottom sway bar bushings on top. Made a new drive shaft to replace bent original. New bushing plate on crank, new flex disk, doubled the rear. Trunion repair new springs. All in all tractor is pretty sweet. Can t say as much for the deck. Low and behold another leak reared it's head, I believe to be axle tubes, but haven't played enough to wanna pull it back down.
Gary
1969 125 42"
