Old 02-12-2015, 02:17 PM
Tankman's Avatar
Tankman Tankman is offline
Default PTO Picture?
While waitin' for a PTO, been looking at the service manual and diagrams.
Something just isn't clickin' in this old head.
Anyone care to share a picture of an installed PTO on a '95 CCC 1641 16 hp Briggs & Stratton engine?
Right now, this is all I can see looking thru the grill opening. I can see the plug (wire) where the PTO will plug in.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 02-12-2015, 04:45 PM
# 3 should be on your engine below the muffler. It keeps # 1 from rotating.
#2 is a spacer, it slides onto the crank shaft between the engine and #1.
#6,7,+8 hold #1 on the crank.
Old 02-12-2015, 05:37 PM
Tankman's Avatar
Sam, there's a piece of steel with a notch and two offset (joggle) bends where it appears the bent angle should be bolted.
The rest seems to be OK.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 02-12-2015, 05:41 PM
No idea what your talking about, post a pic and I'll try to help.
Old 02-12-2015, 05:45 PM
I am betting one of the 3 corners of the PTO will sit in the notch.
Old 02-12-2015, 06:00 PM
OK, the top of #1 will fit below #3. # 3 is nothing but a 90 degree bent piece of sheet metal. # 3 is bolted to the front of the engine. Its only purpose is to stop #1 from rotating. The green area on #1 will fit below the green lip on #3. I've seen #3 bent from a PTO bearing failure. Take the grill off and post a decent pic. and I will be able to help you with more info.
Old 02-12-2015, 06:01 PM
Tank man,
Here is the PTO you are getting.
The key is inside the PTO bore,
Assembly is spacer,pto,bolt,and washer,the stud threads in to the block to keep it all in place.
Hope this helps.
Up to 534 and counting...
Old 02-12-2015, 06:39 PM
OK we have a different setup to deal with. Thanks Lew for posting what he is buying. This is what would be on a later Cub like a 2165. Just my 2 cents it's a better PTO than what came on the 1641 and it's what I put on my 1641. Here's a pic.
Old 02-12-2015, 08:19 PM
Tankman's Avatar
Now, THANKS gentlemen! Seeing the pictures makes sense!
The center bolt (use Threadlocker Red?) holds the PTO in place? The bolt (with Sam's arrow) stops the PTO from spinnin'?
Great! The bolt (again Sam's pointer) is on the block!
Spring is 'round the corner and the boys will be drivin' "their" Cubbie! I usually walk along and never engage the mowin' deck. The little guys have to be at least ten, or more. They are really eager to be Cub Cadets! Pic below was Day 1 with "his" Cub.
The deck is really rusty but, no holes and appears very solid. Greased, lubed. Perhaps the sturdiest "home" deck I've ever seen. Definitely not a "Home Cheapo!" deck.
Now a good blastin', scrapin, and paint. I was thinking spray but, the underside the boys'll have to wear gloves and use brushes!
http://youtu.be/w9dC9qMPWv4
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 02-17-2015, 03:45 PM
Tankman's Avatar
PTO arrived today, installed today, working great today. Thanks Lew!
Now to finish the deck cleanup!
Tankman
'95 CCC 1641
Eastern PA
USMC
