Old 02-09-2015, 11:55 PM
Andy2182's Avatar
Andy2182 Andy2182 is offline
Frame has the holes. These are the same threaded holes you would use to bolt on your snowblower. Obviously the bumper comes off when the blower is on but can stay on with the deck and mule
1641 with a 451 blower "Ramapo"
1782 soon with 3pt and rear PTO "Sam"
2082 with blowed up engine "Buffalo"
2182 with a 60" White "McCoy"
2182 with a 60" Yellow "Indiana"
B2920 Kubota w/ 60" belly, FEL, Back Hoe "George"
Old 02-10-2015, 03:01 PM
gt383mag's Avatar
gt383mag gt383mag is offline
have the tubes bent up need to go to town to grab some flatstock to make brackets with. got 2 inches of snow so thats it for today i get a little seat time
Old 02-10-2015, 05:19 PM
Tankman's Avatar
Tankman Tankman is offline
Looks great! Don't forget show 'n tell when you're done!
I was thinking of making one this spring. My '95 CC 1641 has the standard bumper but, I think a carry-all of some sort is needed.
Hey! Grandsons need their chow while drivin' 'round the property! I'm thinking large enough for a cooler for the little guys and me too!
PS. Just removed my bumper for a repaint 'n clean up. Cleaned and painted the yellow frame part also.
The 1/2-13 bolts did threaded into PEM nuts (pressed in). Cleaned the threads with a tap, new bolts and lock washers, always Never-Seez on the threads during reassembly.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 02-16-2015, 02:38 PM
BassBlaster BassBlaster is offline
Any updates? I don't own a bender so Ill have to go to the muffler shop and get them to bend my stock and I can weld it up myself. Looking forward to your final results.
1994 Cub Cadet 1864
1997 Cub Cadet 2165
Old 02-16-2015, 02:42 PM
gt383mag's Avatar
been cold here and dont wanna heat up the garage and i still need to pick up some flat stock for the mounts
Old 02-17-2015, 06:52 PM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Looks good so far. I can't wait to see the finished product. Someone needs to start making and selling more of these bumpers to help protect these plastic front ends. I could use one for my 2182.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 02-17-2015, 08:55 PM
gt383mag's Avatar
let me get this one finished ... wonder what people would pay for one
Old 02-18-2015, 12:34 AM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
Extreme Motorworks already sells a wide frame bumper for $84.00. It can hold up to 300 pounds of weights.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 02-18-2015, 12:52 AM
gsomersjr's Avatar
http://xtrememotorworks.com/Parts%20...rts%20Body.htm
Old 02-18-2015, 07:17 AM
Yes Extreme does sell a bumper, I could be wrong but from what I can tell it can only be used if you have your mule drive taken off, so It cannot be used while mowing and that's the most important time to have a front "bumper" in my opinion. Extreme's setup is a great looking weight bracket and I like it but does not serve as a bumper when needed most.
882- 50c Mower Deck
Case 646 FEL
Case 446
