Old 04-02-2014, 04:45 PM
TIMCRUTCHER TIMCRUTCHER is offline
Very nice tractor.
I don't use my Cub. I just work on it and look at it. So far it's holding up very well.
Old 04-03-2014, 07:06 AM
yesmar74's Avatar
yesmar74 yesmar74 is offline
That turned out real nice. Good job.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
Old 04-03-2014, 03:35 PM
sawdustdad's Avatar
WOW! that's all I got. Beautiful. OK, I had Beautiful, too. But WOW!
Old 02-20-2015, 03:34 AM
Tacosteelersman's Avatar
Tacosteelersman Tacosteelersman is offline
Thanks for this build thread Cory, amazing work, attention to detail, and end result. Stunning 982D
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 02-20-2015, 06:04 AM
Grampie Grampie is offline
Very Nice Cory, Well Done!
Old 02-20-2015, 08:44 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Cory, 1st class work!!!
I like the touch of the Diesel logo on the bottom RH corner of the grill. It finishes things off. What did you use for that or was it custom designed?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 02-20-2015, 10:49 AM
chris hall's Avatar
chris hall chris hall is offline
Beautiful.
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
