Old 02-22-2015, 11:05 AM
Weld your homemade shoe on the inside also. Once the carriage bolt head wears off you will loose the cap and Ya don't need to be flinging that somewhere next spring with the mower deck!
Old 02-22-2015, 12:28 PM
Tankman's Avatar
Tankman Tankman is offline
Never thought of that! Very important. Thanks for the headsup! Exactly what I will do!
Did use the plow, 1st time working the CCC and the plow. Son loved it.
Might have the wrong length lift rod? Blade runs 1" to 2" off the surface. Skids don't touch down?
Chains and weights on my list!
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 02-22-2015, 06:10 PM
BassBlaster BassBlaster is offline
I think weights and chains are a must for pushing snow. My 1864 got its first workout yesterday with our 6" of white death. I have very large weights(not sure of actual weight), v-bar chains, loaded tires, my 260 pound self and I still lost traction a few times. Only with a full blade of heavy wet snow. Still had plenty of power, just no traction. I couldn't imagine trying to do it without weights and chains. Would take me all day!
1994 Cub Cadet 1864
1997 Cub Cadet 2165
Old 02-22-2015, 06:34 PM
Tankman's Avatar
You got that right BassBlaste! Weights and chains are a must. I'll have them quickly.
FYI. I oil and store my chains in a seal able 5 gallon pail in the off (white) season. When I back tractors
into my barn, blade sits on a block of wood and I usually back up on 2 x's, wheels and chains off the floor. Drip, drip.
For most of this 6" white junque, I used another garden tractor. '85 416-8 16hp Kohler Wheel Horse.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 02-22-2015, 07:37 PM
Thanks for the tip on chain storage. Mine arnt rusty yet. Id like to keep them that way!
1994 Cub Cadet 1864
1997 Cub Cadet 2165
Old 02-22-2015, 07:56 PM
Did you check the height adjuster stop? Maybe it's set so that it won't allow the plow to drop as far as it should. It's located on the back cover plate of the tractor. See red arrow in pic. turn lever counter clockwise as far as it will go but when you feel it stop don't force it any further or you'll bugger up the little bolt that keeps it from coming apart. If you remove the tunnel cover you can see how it works.
Old 02-22-2015, 08:28 PM
Tankman's Avatar
I'm willing to bet you hit the nail on the head Sam!
Only Cub Cadets to the rescue, again. Thank You Sir!
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 02-23-2015, 03:21 PM
Tankman's Avatar
It should. The 1641 sit's a little higher in the front because it has a different front axle. Worst case is you may have need to modify the front attachment points to drop the plow a bit.
Tried the turn screw back of the Cub. Didn't work.
Sooooooooo, cut the lift rod (P/N 747-3088) and added 2" to the length (1/2" rod). Worked like a charm. Nothing hitting, plenty of height for overland travel. Blade drops down to the earth now, pushed snow easily.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 02-23-2015, 03:51 PM
No pic? You know better.
Old 02-23-2015, 04:17 PM
Tankman's Avatar
On the deck in the barn while I'm "playing" with the Cub's lift. I had added 'bout 3" but then the blade was too low to travel properly. 2" is perfect. After adding the 2" the "dial-a-height" rear of Cub, works too!
I'm 'posed to be doing my chores while the Ms. is at wo....wo....work.
Years ago I loved but never owned, the red IH cubs.
As far as the new Cubs, I only saw MTD junque.
This '95 1641 changed my thoughts 'bout Cubs. Not the Home Cheapo models, the Cyclops are not the same. Nice 1641 but the yellow paint job, awful.
Sorry Sir, pic's will follow.
Tankman
'95 CCC 1641
Eastern PA
USMC
