Old 03-03-2015, 03:37 PM
raytasch raytasch is offline
I've had excellent results using RTV gasket material. Follow directions and it works good. Don't over torque and allow it to set. Last couple FelPro / Chevy gaskets had rubber valve cover and oil pan gaskets.
Old 03-03-2015, 07:56 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
A pre cured rubber gasket is gonna squish out and leak.
RTV and silicone is also an adhesive and thus works in many places. If you clean the mating surfaces with acetone, etc.
Use that same rtv and silicone on two greasy surfaces and it too will squish out and leak.
Try a bead of cured rtv or silicone as a gasket and it will squish out and leak.
The gasketing described by J-Mech is retained mechanically by the item or the gasket assembly. Effectively turning the rtv/silicone into an o-ring.
Without the special o-ring groove machining required.
Old 03-03-2015, 08:17 PM
Just my 2 cents, I do what ever keeps the oil in, the dirt out and I hate leaks. Do what works for you.
Old 03-03-2015, 11:11 PM
bocephus1991's Avatar
If your ordering gasket material from McMaster Carr order a punch set for making holes, makes it s heck of a lot easier! Or if you have empty brass shell casings they can work too. I made a new pan gasket for my k301 just bought a roll from autozone. Still have a bunch left!
Brian
Old 03-04-2015, 07:18 AM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
A company likes return customers better. If everybody was able to reuse their gaskets they would have very little sales in new gaskets.
I lost track of what I own a long time ago!
Old 03-04-2015, 10:18 AM
Agree one hundred percent with that statement. Customers also want a gasket set that works well and lasts. Nothing more frustrating than a gasket set that is of poor quality material, poorly punched and cut. Years ago, I was playing mainly with the larger Ford farm tractors, buying gaskets and bitchin' at the quality. I was directed to the use of the gasket material in a tube and that is where I've been since. Granted, it is not for all applications but for many, it is very good.
Old 03-04-2015, 12:07 PM
j4c11's Avatar
j4c11 j4c11 is offline
For those of you who use RTV in place of a rear end gasket, any concern with the stuff flaking off into the oil? What about removal and cleanup when you do have to pull the cover off the rearend?
Old 03-04-2015, 12:25 PM
Not really. As long as you don't overdue it anyway. As far as cleaning it off later.... Die grinder and a wire wheel.
Old 03-04-2015, 12:26 PM
There are a lot of gaskets now days that are reusable. But..... they don't last forever. You can reuse them once or maybe twice and that's about it.
Old 03-04-2015, 06:16 PM
I use these on my jeeps. Great for a diff that you're into more than normal, reuse able trans and cover gaskets, over and over. Wish they made a cover gasket for our tractors, maybe worth a shot to ask? check them out.
lubelocker.com
