Old 03-05-2015, 12:08 PM
Cubby2084 Cubby2084 is offline
Default 2084
Hi, I have a 2084 with what I believe is a 451 blower. The shaft that runs through the impeller from the back to the front auger gearbox has bad ware and the impeller fan is rubbing on the back casing. I have contacted my local dealer who informed me the part can not be bought any longer. Does any one know of a solution. Cheers, Neil.
Old 03-05-2015, 12:19 PM
Welcome to the forum Neil!
To be able to help you more, need to know what all is worn. The shaft that is connected to the impeller runs the auger drive. It is only held onto the impeller with a spirol pin. The impeller "floats" on the spline shaft out of the rear gear box. Unless the thrust bearings in the auger drive gearbox are wore out, or the impeller is bent, it should not be rubbing. I just rebuild the auger drive gearbox on my machine. As long as the case is not damaged beyond repair, it should be fixable. I suggest taking the augers and impeller out, (they come out as an assembly), and go from there. Lets find out why the impeller is hitting first.
