Old 03-09-2015, 12:40 PM
gt383mag's Avatar
gt383mag gt383mag is offline
Default Cyclops lift control valves
my brother has a 1863 we are going to make into a 1864 by adding power steering. we would also like to have 2 hydraulic valves for angle blade and such. am i correct that the valves are stackable? has anyone made lines with those kinds of fittings successfully? or what models came with the double valve setup if any that i might be able to look for lines from oem if any are available?thanks guys
Old 03-09-2015, 02:00 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
The double valves were optional on all hydro-lift cyclops. It was a rare option from what I have seen. Sam had the fittings to stack them made. I think a good hydraulic shop could make the lines/fittings.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 03-09-2015, 02:23 PM
gt383mag's Avatar
thanks shrew im sure sam will chime in soon enuff...
Old 03-09-2015, 04:03 PM
gt383mag's Avatar
is there room enuff in the dash for three? not sure we need that many but i guess if we are in there and theres enuff room who knows... i can send you a check sam
Old 03-09-2015, 11:46 PM
V30crewcab V30crewcab is offline
I think theres holes stamped in for 3 valves already.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 03-10-2015, 09:18 AM
jimbob200521's Avatar
Here is a thread I have bookmarked from this site as I am going to do the same thing this spring, add a 2nd valve to my 1864. There's some good reading material in there
http://www.onlycubcadets.net/forum/s...t=28750&page=4
-Ryan
Old 03-10-2015, 11:02 PM
Dave01's Avatar
Dave01 Dave01 is offline
I added a 2nd valve to my 2084 to run front hydraulics. I bought a used kit from one of the parts vendors, wasn't too expensive and had all fittings and brackets. They stack easily, just have to extend the slot in the dash for the 2nd control handle.
1864 w/48" deck, 2084 w/54" deck + 54" blade, 3204 w/48" deck
Old 03-11-2015, 09:18 AM
Yep I have the adapters that go between the valves when you stack them.
This is the pricing for the valve adapters
Valve adapters are $7.00 ea
Shipping is $3.00 for 1-3
This is what they look like.
Old 03-11-2015, 10:28 AM
I don't suppose you have any under-dash pics of the install? I'm curious how hoses are routed as well as the valve mounted/attached.
-Ryan
Old 03-11-2015, 10:42 AM
Dave01's Avatar
I don't, and am not near the tractor right now, sorry. The valve mounting is very obvious, just attaches to the existing valve and the lever location is directly above the existing dash lever, you just extend the rectangular cutout in the dash. Hose routing is just the easiest path that doesn't come in contact with any moving parts, was very easy. This is for adding front outlets, not sure of the challenges of adding power steering.
