Old 03-10-2015, 09:58 AM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
Originally Posted by j4c11 View Post
Ok well since this is an issue for so many users I've put together a small utility to rotate the pictures and resize them to forum size(450x450). The issue here is that Apple chose to not physically rotate the pixels, but instead store the orientation in metadata inside the file. This metadata gets stripped by some programs or is simply not interpreted/read at all by others, although it is standard practice to do so.
To fix, simply go to rotatepic.info , select the file you would like to fix, click submit, you get back the cleaned up image. You can save it and use it to post on the forum. Keep in mind depending on resolution it may take a little bit to upload. Only works for JPEG files.
This should work straight from your iPhone as well using Safari, but only for iOS version 6.0 or higher, since Apple didn't enable file uploads until that version. So if you're not around a computer, this is a good solution.
The tool is very fresh off the press so any feedback is welcome. Enjoy!
Fantastic!
I lost track of what I own a long time ago!
Old 03-10-2015, 05:58 PM
Hi my name is Mike and I am a crooked picture taker. I have now seen the err of my ways and have found a way to fix them. Praise the ........................jC411??
Seriously thanks again, I had no clue how to do this
