#21
Just my taste I suppose. I'd rather be working up firewood, toiling in the veggie garden, etc, than mowing grass. Cheers.
Cub Cadet 129 48" deck - grass mowing 38" deck - backup deck 42" front blade |
#22
Oh where to begin! I'd call this maintenance/project work but knowing me, it'll happen in spring so I think that counts!
![]() 1864 - Remove cab, remove fenders, and paint/coat the underside in truck bed liner to add protection since this will be the tractor most exposed to the elements year round. Then I plan on putting some sound deadening material in the cab and then on top of that, the "carpet" material used in the big boy tractors. I'd also like to put some sound deadening between the engine/trans and the drivers seat so it's a lot quieter and nicer to be in next winter. I also need to do some better weather stripping where the cab meets the hood/front of the tractor to eliminate (or at least greatly reduce) any wind that made it in this year. I also plan on coating the foot rests in the truck bed liner to add texture and protection to them, as well. 2284 - This will be the year of addon's, and not tractor buying/selling/swapping! I want to put some money into the machines I have instead of having a different machine every week (well, unless a REALLY good deal comes along ) I plan to get some AG tires on the rear, some ribbed tires up front, and add an Xtreme 3pt to the rear. At that point, the budget should be about tapped out.
-Ryan
#23
Give me grass!!!! |
#24
I'm the same way. Absolutely hate cutting grass. I do it maybe once a month. Lol I'll split wood all day long....splitter or maul/axe. Its relaxing IMO to do firewood... Weird right?
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169. Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3. |
#25
i will be pulling the engine from my 108 to replace the driveshaft and put in a kevlar clutch, i also need to go to the local cub graveyard and pick up a rear 3 point since i ordered a brinly adapter from jeff.
#26
As I read the thread, there is a lot of hydro pump gasket replacements going on! I for one, will be doing just that, very, very soon! Also changing the Hy-Tran and Cub Cadet trans filter on my 1450!
#27
I can't wait to start working on cubs again, as soon as I get my driveshaft from Jeff it will be go time. I also got a cub 86 I need to go pick up so I can get it going and see what it needs, I'd really like to have it ready for some shows this summer.
