Old 03-19-2015, 08:00 PM
Originally Posted by Mechanic View Post
I cannot totally read the model number. There is a faint M, no 1, a faint 8 and a faint S.
Spec. 24647
Serial 2011508446
The model is: M18S, so yes that is correct.
The spec # matches as a Mag 18
I am new to this model engine. Are aftermarket rebuild kits available for it?
Only if you have deep pockets (you can replace it for the same price) and know a shop that can sleeve. Pretty limited as far as piston sizes and internal parts availability.
Old 03-20-2015, 09:36 AM
ccannon222 ccannon222 is offline
J-Mech,
Thank you for the explanation. I should be able to get to my spare engines this weekend. I have two M15's and a M18. I know the spec numbers on the engines are the same. I will try to take some pics of the carbs and see if I can pull the numbers off of the carb.
You mentioned the M15 may have a WOT limiter. Would this be external to the engine limiting the amount the carb throttle could be opened or would this be something internal?
Chris
Old 03-20-2015, 12:54 PM
Chris
Should be external. I noticed in the parts book that for some reason it states different part numbers for the governor control rod between the two engines. May be just a minor difference/change and totally irrelevant, but the limiter may be in the linkage.
Old 03-20-2015, 01:34 PM
The carb that is on the engine has both low and high speed jet adjustments on it.
This engine will be rebuilt and made to breathe a bit better. I am going to need to make the carb perform up to the engines expectations.
I have only had the tractor for a few days and it has not been in the shop yet. Paid $350 for it without a deck.
Spec. 24647
Serial 2011508446
I just looked at the tag on my 1535 engine.
Says it's M 18S and spec # is same as yours, 24647.
Old 03-20-2015, 08:33 PM
Mechanic Mechanic is offline
Thank you for checking the numbers on your M18S.
So, by what method is the engine de-rated to 15 horse.
Old 03-21-2015, 06:23 AM
Marketing?
Old 03-21-2015, 10:13 AM
Unless I missed something, this page says the carbs and all important internal parts along with governor linkage is the same between the 186X engines and the 153X engines. Along with other applications.
http://www.partstree.com/parts/cub-c...59/carburetor/
Old 03-21-2015, 10:38 AM
This is from Small engine warehouse
Repower old Equipment
Cub Cadet 1541 Category
Available replacement parts listed below, please click product number to view more information about each replacement part.
Original Model: Kohler Magnum M18 24646
This was an 18hp engine that Cub Cadet labeled a 15hp.
Old 03-21-2015, 11:47 AM
Kohler parts list says the m 18s spec 24646 and 24647 used the same carb kit with either a 52-053-50 or 52-053-66 carburetor.
Old 04-18-2015, 07:28 PM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
The engine I pulled out of the 1541 has an M18s spec tag but the tin says Magnum 15
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
