Old 03-29-2015, 11:16 AM
Feoe.RL Feoe.RL is offline
Default K301 Rebuild Question
So i finally got my Block clean rust free and painted and ready to be put back together with new piston, rings all new gaskets, ect. I have been doing a little research on here and i just want to ask this before i get it wrong. Should I or should i not reinstall the Balance Gears???
Old 03-29-2015, 11:42 AM
leave them out
Old 03-29-2015, 11:51 AM
Most ppl are told to leave them out because when they go bad they tend to put a big fat window in the block, nobody wants that.
That said, some ppl replace the needle bearings/shafts that are worn and don't intend to run them over recommended rpm's, so they would be safe to use them.
A lot of ppl can't tell the difference with them in or out, others do see a difference but most agree it is not a big difference.
and IIRR the 16 hp don't come with them.
So it is your call.
You can't go wrong leaving them out, as no window effect will present itself.
Old 03-29-2015, 12:01 PM
After I am finished with this restoration project i highly doubt ill be doing anything heavy with this tractor mainly just for shows. But if there is not much difference with or without them i think im just going to go ahead and leave them out. Thank you both for your help.
Old 03-29-2015, 01:38 PM
bocephus1991's Avatar
I would leave them out. All they are is a hand grenade waiting to explode. I took them out of my k321.
Brian
Old 03-30-2015, 09:46 AM
dbuck dbuck is offline
Smile
The first thing I do, when tearing down a K-series that has grenade gears is throw them in the scrap bucket.
Old 04-06-2015, 09:41 AM
Juicybusa Juicybusa is offline
Kirk Engines has a crank balance plate that really smooths a 301. A bit pricey with installation but well worth it. What a difference!
