Old 04-03-2015, 04:50 PM
Imaddy Imaddy is offline
Default 1772 Wont Now Start!
I'm hoping some one can offer me advice.
I've recently refurbished my 1772 and in the process changed all the fluids and filters. However, it simply wont start now despite me bleeding the fuel lines at all points so I know there's no air in the system.
Prior to doing the service the Tractor started easily on one battery but it now takes a couple to simply turn-over the engine and then it is sluggish.
I'm at a loss as to the problem so suggestions most welcome please.
Many thanks
Ian (UK)
Old 04-03-2015, 04:54 PM
You have to bleed the high pressure lines while cranking.
Did you do any rewiring?
Did you disassemble anything on the engine?
How old is the battery?
How long since it last ran?
Old 04-03-2015, 05:00 PM
is that at the injectors?
Old 04-03-2015, 05:01 PM
as I followed the procedure in the manual.
Old 04-03-2015, 05:02 PM
Yes at the injectors
Old 04-03-2015, 05:03 PM
yes, done that, its a mystery
Old 04-03-2015, 05:12 PM
Glow plugs working?
Does it smoke?
You didn't answer any of the other questions......
Old 04-03-2015, 05:17 PM
its giving off a slight puff of white smoke but obviously not igniting the fuel, unsure about the glow plus, how should I check them?
Old 04-03-2015, 05:18 PM
Can you first tell me a little more about what all you did? It would really help the diagnosis...... as is I'm stabbing in the dark.
Old 04-03-2015, 05:20 PM
I'm sorry, I missed your other questions - der!
Did you do any rewiring? A = No
Did you disassemble anything on the engine? A = No
How old is the battery? A = New, and both fully charged
How long since it last ran? A = A couple of months, with fresh fuel now.
