Old 04-07-2015, 11:40 AM
pullin pullin is offline
Default Axle housing bolt pattern
I'm going to design my own wheelie bars for my sons pulling tractor. What I am looking for are the bolt hole dimensions for the axle housing on a model 126 with external brakes. A print or equivalent would save me alot of measuring to get the correct measurements of that circular pattern. Thanks to all in advance...
Old 04-07-2015, 11:46 AM
Use a piece of paper. Lay it over the housing. Draw the bolt holes. Transfer that to the metal you are working with.
Old 04-07-2015, 11:49 AM
That is one way... I'm looking for a more precise drawing.
Old 04-07-2015, 11:53 AM
How can you be more precise than taking the measurement directly from the housing?
Old 04-07-2015, 12:14 PM
jcsmith jcsmith is offline
Default pattern
Maybe a new axle housing gasket will get you started with the bolt holes and pattern. Better than taking housing off, tho that would be easier for the outside measurements.
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 04-07-2015, 12:19 PM
The rear end is not unassembled. It would be awful hard to be precise laying paper over the tire side of the housing. Thank you for your help though.
Old 04-07-2015, 12:22 PM
As jcsmith pointed out it might be easiest to buy a new gasket and use it for the pattern.
Old 04-07-2015, 12:24 PM
A gasket seems like a good way to get them. thanks
Old 04-07-2015, 12:31 PM
jimbob200521's Avatar
I still don't see what's wrong with John's suggestion
-Ryan
Old 04-07-2015, 12:39 PM
Terry C's Avatar
Terry C Terry C is offline
I have a cad drawing of the back plate, but I'm not at home but I will be tomorrow if you can wait. If I remember correctly you can scale the distance between the holes because they are an even number like 6.5 or 6.75.
Get engineering paper from the stationery store (1/4 grid) and lay the back plate on it lined up with the grid then you can count the squares. Or wait till tomorrow
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
