Old 04-12-2015, 05:04 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Originally Posted by jwakeman View Post
The saga continues. Went to Cub dealer, got new bearing - inner and outer. Get it on the tractor, and when the wheel is pushed as far back as possible on the spindle, there's around 1/8" of space between the outer bearing collar and the washer holding the wheel on. Am I missing a piece somewhere?
Got (2) of part 1 on this drawing: http://www.partstree.com/parts/cub-c.../front-wheels/
Maybe it is a non Cub Cadet rim?
What does the other side rim look like?
Does your 123 now move under it's own power?
Old 04-12-2015, 06:54 PM
I have a couple of wheels that are the same way, when someone drives the tractor with bad bearings it tends to wear the edges of the hubs away.
Get a 3/4" washer and put it on the spindle then put the wheel on.
Old 04-12-2015, 09:27 PM
jwakeman jwakeman is offline
The rims look to be original. It matches the other side which does not have any spacers and the same bearing setup. I'll get some washers which should fix it.
It runs great under its own power now. Surprisingly strong. With the loader I don't have much traction at all on the back, so I need to investigate doing something for rear ballast now....
Old 04-12-2015, 09:33 PM
mattkarr mattkarr is offline
Default yes
My 127 quit moving and the hyrdo fluid had turned to jelly plugging the filter I cleaned it all out and it works great
