View Poll Results: What do you suggest
Keep searching, you fill find a guide 3 60.00%
Keep looking for a 105 blade setup 3 60.00%
Buy an "x" model, and modify the frame to fit 0 0%
Step away from the tools, you are scaring me 0 0%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Old 04-13-2015, 07:16 PM
Flingarrows's Avatar
Flingarrows Flingarrows is offline
Default Is there a cross-reference guide on attachments?
I did a google search on 105 site:http://www.onlycubcadets.net/ looking for attachments that will fit on a 105, that also fit other models.
I looked through a lot of posts but have not found info relating to what other tractor attachments will fit a 105. Does such a list exist?
Im looking for a snow blade for my 105, but not seeing too much right now. I am not opposed to modifying/fabricating another model's mount to fit the 105. I've done a lot of truck drivetrane swaps that require welding up custom mounts, so, I'm good there.
I am open to any info, suggestions, etc.
Old 04-13-2015, 07:25 PM
This is the list of attachments for a 105 from the Cub Cadets parts site.
*Attachments
220 32" Lawn Sweeper, 190-220-100
222 38" Lawn Sweeper, 190-222-100
368 10 Cu. Ft. HD Utility Cart, 190-368-100, 190-368A100, 190-368B100
38", 42" 3 Spindle Mower
38", 42", 48" Quick Attach Hitch
42" Back Blade
42" Push Blade
42", 54" Push Blade - 1
425/425A 17 Cu. Ft. Utility Cart
438 Broadcast Spreader
48" 3 Spindle Deck
521 Utility Cart
653/653A 10 Cu. Ft. Utility Cart
CC36, CC42 Snowthrower
Gearbox #1
Helper Spring
Manual Lift Helper Spring & Handle Adapter
Peg Tooth Harrow
QA36, QA42 Snowthrower
QA36A, QA42A Snowthrowers
Sand Trap Rake
Tiller #1
Tiller #1 Front Drive
Tiller #1A Front Drive
Tiller #2, Front Hanger
Old 04-13-2015, 07:27 PM
Thanks Sam, can you post a link to the site?
Old 04-13-2015, 07:59 PM
you can go here too,http://www.ccmanuals.info/pdf/
Up to 534 and counting...
Old 04-13-2015, 08:01 PM
Thanks for the link
Old 04-13-2015, 08:04 PM
I voted twice...
Old 04-13-2015, 09:02 PM
I voted twice...
LMAO!
What you are really looking for a Quick Attach (Q/A) Narrow Frame front blade, although the bolt on ones will also work if you have a mule drive.
I don't think they are that hard to find, Lew probably has 75 or 30 of them squirreled away.
Old 04-13-2015, 09:24 PM
Thanks guys.
Yosemite, is Lew a member or a business?
Old 04-13-2015, 09:30 PM
Yes he is!
He's a little far away though (New Jersey). http://www.onlycubcadets.net/forum/member.php?u=2828
Old 04-13-2015, 09:35 PM
Yes he is far.
