Old 04-14-2015, 09:07 AM
o---o o---o is offline
Default 3 point power down?
1541 with a CCC 3 point hitch
I can lift the 3 point arms by hand. Is there a quick/easy/cheap way to make them so they don't raise?
I don't really need power down, but I don't want them to raise when pulling a yard cart on a drawbar.
Old 04-14-2015, 01:17 PM
gdheck's Avatar
gdheck gdheck is offline
You could get a 2 piece set collar and clamp on the lift links, just above the lift arm. Just leave enough room for everything to pivot right.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 04-14-2015, 10:28 PM
cuber cuber is offline
I think Extreme motor works makes a float lock out pin for cat 0. I've seen pictures of it just not sure who had it.
Old 04-14-2015, 10:33 PM
Is it this?
Quietline Float Lockout Pin
Used to remove the float in your quietlines lift system. Great for push blades to get down pressure. UNPAINTED
PN# CC-03-015
$16.00
Old 04-14-2015, 10:39 PM
Nope that's not it. It is a rectangle/oval piece that goes in the slot of the lift arm. I'm talking about the lift arm that sticks out of the back of the rear hitch cover plate and the other end attaches to the lift cylinder.
Old 04-14-2015, 10:46 PM
Ok, I got ya now. I've not had fenders off of one yet, do they need to come off to access that part? I looked under there briefly to see how they come off, but all I saw was gas tank lol.
Old 04-14-2015, 10:51 PM
no there should be a hole/slot on the back of your hitch plate on the right side. And when you raise and lower the hitch you should see this lift bar going in and out that hole. I've been searching for that lockout pin for the last 20min and can't find it anywhere. I'm positive I saw it on extremes site but I don't anymore... maybe you should email them. I know that it exist but I just can't find it LOL
Old 04-14-2015, 11:03 PM
http://onlycubcadets.net/forum/showt...t=14633&page=2
Old 04-14-2015, 11:14 PM
You are awesome, thank you so much for finding that link
I'll look on his site or email him, if he doesn't offer them at least it looks simple to build one.
Old 04-14-2015, 11:22 PM
Talking
No problemo, your welcome. I knew I saw it before so I had to keep searching until I found it to make sure I wasn't losinghttp://onlycubcadets.net/forum/images/icons/icon10.gif my mind
