Old 06-13-2010, 11:08 AM
Boats1183 Boats1183 is offline
Question I Need help Identifying my mower deck?
I tried to order a new center spindle for my mower deck and I am not sure which one it is, it's mounted on a 1975 1450, the serial # for the deck is 0320017U0384639, I've looked through some of the links on this sight but am having trouble trying to identify it can anyone help me please. Thanks in advance
Old 06-13-2010, 12:32 PM
How about posting a Picture of the Deck, the Model Tag, and advise on the size (38, 44, 50").
The 0320017U0384639 does not bring anything up.
Old 06-13-2010, 12:36 PM
I could identify it from a picture ...but as a start most of the 1450's I have seen had either a 44a or 50 deck. Is the center pulley setup for a narrow or wide belt? (the wide one is 5/8 and the narrow one is either 1/2 or 3/8 depending on who you listen to.
If it is a stamped deck with no cast iron ends or center pieces, the above applies.
I'm sure someone here has better info than I but that should get you started.....Can you read the model number off the serial plate??
Old 06-13-2010, 03:54 PM
Thanks for the info, I will get a picture and post it later today. The number in my original post is off of the tag on the deck and I am not sure if the model # is the same way as my 1450 (2050065U567891) the underline portion is the model (I think)
Old 06-13-2010, 04:58 PM
young enthusiest's Avatar
Model # will be 38, 44 or 50, if I'm correct. That's the number your looking for
